Link object motion to texture transform?
Forums: Link object motion to texture transform?
Postby GOTHACOM » Mon May 16, 2022 1:42 pm
GOTHACOM Mon May 16, 2022 1:42 pm
Hello,
I'm wondering if it's possible to control the transformations of an Octane procedural texture with the motion of an external object?
I tried to add a standalone Texture Locator and use the embedded Octane Projection with the procedural, but I get an error:
Tried to access null node pin
Tried to access null item
Tried to access attribute via invalid ID A_VALUE (185)
We can't evaluate items of a different version (version 0)!
Is there an alternative way to do that?
Thanks.
Regards.
G
GOTHACOM
Re: Link object motion to texture transform?
Postby funk » Tue May 17, 2022 2:21 am
funk Tue May 17, 2022 2:21 am
It looks like Modo texture locators only work for Octane image nodes.
The modo plugin allows you to connect modo channels to Octane channels using the method described here:
https://docs.otoy.com/ModoH/ModoPluginM ... annels.htm
I have attached a file showing you how I'd control an Octane node from a modo item (locator). You can move/rotate/scale the locator, and this will update the noise node.
octane_procedural_external_control.7z
(11.17 KiB) Downloaded 69 times
Win10 Pro/ Ryzen 5950X / 128GB / RTX 4090 / MODO
funk
Postby GOTHACOM » Wed May 18, 2022 7:46 am
GOTHACOM Wed May 18, 2022 7:46 am
Thanks man, my bad I haven't thought to expose floating input channels in the schematic... I wasn't aware it was possible at all.
Thank you very much!
G
GOTHACOM
Return to Foundry Modo
Users browsing this forum: No registered users and 25 guests
Fri Apr 26, 2024 3:23 pm [ UTC ]
