The curve weight only supports one weight map name (potentially the last in the list). So you will see some odd behavior like this with you have multiple maps for a curve.BTW, I'd like to report something I noticed in my experiments.
I set weights for the polygon object and the curve object with set weight MOP. This works perfectly for both objects. Thanks!
Next I used Remap to animate the Wightmap. The name of the weights is changed from the name of the weights set in Set Wight MOP to another name.
And when animated, the polygon mesh works perfectly with the changed weight name.
The curve object does not animate with the changed weight name, but it does animate with the name set in set weight MOP.
It seems that the changed weight name is not being recognized. (But it still animates with the name set in Set Weight MOP.
I have reported this just in case.
Users browsing this forum: No registered users and 20 guests
