Notiusweb wrote:Can't you just use lock aspect ratio, like if it was 1920 x 1080, click the lock aspect ratio on resolution and then you can increase/decrease just one (ie width) and it will reconfigure the other (height). At least standalone has this feature.
jobigoud wrote:Changing the height of the image should already work as you expect. For the width I think the easiest way to do this is to update the "Scale of view" by the same factor you changed the image width. So for example if you double the width double the scale of view.
Return to Development Build Releases
Users browsing this forum: No registered users and 7 guests
