[BUG] Octane Output doesn't write frame numbers.
Forums: [BUG] Octane Output doesn't write frame numbers.
Postby Exaco » Mon Sep 25, 2023 2:04 pm
Exaco Mon Sep 25, 2023 2:04 pm
Hi there,
So if I enable Cryptomatte and other AOV's and keep the default suffix/prefix it will just render the sequence to a file name "FileName_blenderoutputname00000_ViewLayer_000" without changing the numbers.
Also if I try to remove the Prefix completely and in Suffix add something like "$_####.exr" then it renders the files as:
"[OctaneExport]blenderoutputname0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000$_0000.exr"
How to setup it properly or where I can find earlier versions of Octane/Server ? It worked fine in some previous version few months ago, in fact this project I'm using was working properly and rendered fine before. After OS reinstall I opened it ( together with latest Blender Octane Edition & Server installed ) and it stopped working, the first example was on fresh new empty scene so it's not just my old scene issue.
Exaco
Re: [BUG] Octane Output doesn't write frame numbers.
Postby AlexeyAdamitsky » Tue Sep 26, 2023 8:20 am
AlexeyAdamitsky Tue Sep 26, 2023 8:20 am
I reported this bug as well. There are enough production breaking bugs like this after 27.16 which makes it impossible to upgrade to later version.
I recommend 27.16 as the most stable so far.
AlexeyAdamitsky
Postby Exaco » Tue Sep 26, 2023 12:32 pm
Exaco Tue Sep 26, 2023 12:32 pm
AlexeyAdamitsky wrote:I reported this bug as well. There are enough production breaking bugs like this after 27.16 which makes it impossible to upgrade to later version.
That's what I'm going to try thanks.
Btw for Free Tier I've found the download here in case someone has same problem and needs it: https://blenderartists.org/t/octanerend ... 35337/1395
Exaco
Return to Blender
Users browsing this forum: No registered users and 9 guests
Wed May 22, 2024 12:26 pm [ UTC ]
