Scatter on Surface alignment issues
Forums: Scatter on Surface alignment issues
Postby pegot » Tue Apr 06, 2021 1:46 pm
pegot Tue Apr 06, 2021 1:46 pm
Having trouble aligning cones on a cube so that their points are all oriented outwards with Scatter on Surface. Works in Stand Alone but unable to reproduce in Octane Blender.
Please refer to this thread for more info and screen shots:
viewtopic.php?f=23&t=77367&p=398897#p398897
Win 10
3.7Ghz i9 10900k / 64GB
ASUS STRIX Z490-E
PSU: PowerSpec 850Wd
RTX 3090 Asus Tuff
Network rendering:
Win 10
4.2Ghz i7 7700k / 64GB
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 Ti EVGA Hybrid
RTX 3080 ASUS Tuff
GTX 1080ti SC Black (wc)
pegot
Re: Scatter on Surface alignment issues
Postby linograndiotoy » Wed Apr 07, 2021 1:48 pm
linograndiotoy Wed Apr 07, 2021 1:48 pm
Answered:
viewtopic.php?f=23&t=77367&p=398954#p398954
You need to set Normal Align to 1.
linograndiotoy
Postby pegot » Wed Apr 07, 2021 8:17 pm
pegot Wed Apr 07, 2021 8:17 pm
There must be some other setting I have wrong because it is still not working. See attached screenshot and blend file.
Cone-SurfaceScatter.blend
(889.96 KiB) Downloaded 109 times
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Fri Apr 09, 2021 1:33 pm
linograndiotoy Fri Apr 09, 2021 1:33 pm
You have the Smooth Normal option on.
Also, you need to rotate the cone geometry (so in Item mode) by -90 degrees on the x axis.
linograndiotoy
Postby pegot » Fri Apr 09, 2021 7:46 pm
pegot Fri Apr 09, 2021 7:46 pm
Thanks ……… I finally got that set up to work. There seems to be a discrepancy between how Scatter on Surface works in Octane Blender and Stand Alone.
In Stand Alone checking or unchecking the “Smooth normal” option has absolutely no effect on the Cones’ orientation around the cube. Even more puzzling is that that in Stand Alone the cones all face outward around the cube without having to change the rotation value – it works keeping the vale at 0. But in Blender Octane it is necessary to change the rotation value to -90 as you instructed. I am wondering does this have to do with Blender’s internal coordinate system?
Win 10
ASUS STRIX Z490-E
RTX 3090 Asus Tuff
Network rendering:
Win 10
AsRock SuperCarrier
PSU: EVGA 1200w
RTX 3080 ASUS Tuff
pegot
Postby linograndiotoy » Sat Apr 10, 2021 1:51 pm
linograndiotoy Sat Apr 10, 2021 1:51 pm
pegot wrote:Thanks ……… I finally got that set up to work. There seems to be a discrepancy between how Scatter on Surface works in Octane Blender and Stand Alone.
Blender handles polygon normals differently than Standalone. A "standard" Box in Blender is somehow different than a Standalone primitive Box.
Blender is using Y for depth and Z for height. Just the opposite of Standalone. That's why we need to rotate the geometry in Blender so it's "aligned" to the Y axis.
linograndiotoy
Return to Blender
Users browsing this forum: No registered users and 20 guests
Fri Apr 26, 2024 9:04 am [ UTC ]
