Difference between plugin and standalone, perfomance problem
Forums: Difference between plugin and standalone, perfomance problem
Postby Dmi3ryd » Thu Dec 13, 2018 3:44 pm
Dmi3ryd Thu Dec 13, 2018 3:44 pm
Good day.
My project is made in a blender. For render, I use octane.
There is a difference between plugin and the standalone octane.
The plugin recalculate each frame with large amount of time, while standalone octane make it without loading the scene every time.
What could be the problem? How to set up a blender plugin for a similar behavior as in a standalone octane?
Thanks.
OctaneRender_4_01_1_win
Blender_Octane_Edition_16.3_2.79
Octane_Server_4.0_-_16.3
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
Dmi3ryd
Re: Difference between plugin and standalone, perfomance problem
Postby J.C » Thu Dec 13, 2018 5:30 pm
J.C Thu Dec 13, 2018 5:30 pm
This is a common issue. The best would be to export to ORBX and render in standalone.
To speed it up in Blender we need to know few things:
- What is your scene animation mode?
- Are there there movable objects or camera only?
- What type of objects are you using (proxy, scatter etc.)
- Do you use modifiers?
System – Windows 11
J.C
Postby Dmi3ryd » Fri Dec 14, 2018 2:51 pm
Dmi3ryd Fri Dec 14, 2018 2:51 pm
I am not sure that this is a good solution in my case. Each export takes about 40-50 minutes, the scene is very heavy.
Animation mode – Full
Only camera
Actually, I don't even know what it is.
Yes, sure.
Dmi3ryd
Postby Dmi3ryd » Fri Dec 14, 2018 2:55 pm
Dmi3ryd Fri Dec 14, 2018 2:55 pm
I also have a few questions about how to use and what it is.
Marked with red arrows.
Dmi3ryd
Postby J.C » Sat Dec 15, 2018 12:52 am
J.C Sat Dec 15, 2018 12:52 am
Switch to Camera only animation mode. This should speed things up. If possible flatten modifiers too.
Here is the description of the object types:
https://docs.otoy.com/BlenderH/BlenderP ... yTypes.htm
System – Windows 11
J.C
Postby J.C » Sat Dec 15, 2018 1:11 am
J.C Sat Dec 15, 2018 1:11 am
If you set animation mode to "Movable proxies" it will allow to render transformed and distorted objects. Camera animation is also taken into account.
"Camera only" renders static objects with only animated camera. Probably the fastest mode.
"Full" mode does probably both. I could not any info on this.
System – Windows 11
J.C
Return to Blender
Users browsing this forum: No registered users and 26 guests
Fri Apr 26, 2024 9:50 am [ UTC ]
