Uv not updating
Forums: Uv not updating
Uv not updating
Postby dktw » Sun Sep 25, 2022 10:26 pm
dktw Sun Sep 25, 2022 10:26 pm
I’m having weird thing in Octane Blender 3.2, in render view I’m setting material with basic texture map, changing UV and it changes in edit mode but once going out to object mode the changes in UV are ignored. Restarting render doesn’t help UV stays the same, what could be the problem?
dktw
Re: Uv not updating
Postby grimm » Mon Sep 26, 2022 7:11 pm
grimm Mon Sep 26, 2022 7:11 pm
It might be a Blender bug, are you able to try the Blender 3.3 version of the plugin? It might be fixed in that version.
Linux Mint 20 x64 | Nvidia GTX 980 4GB (displays) RTX 2070 8GB| Intel I7 5820K 3.8 Ghz | 32Gb Memory | Nvidia Driver 460.56
grimm
Re: Uv not updating
Postby dktw » Tue Sep 27, 2022 6:44 pm
dktw Tue Sep 27, 2022 6:44 pm
Thanks Grimm for your comment, unfortunately I am using blender octane prime (free tier) so 3.2 is the newest. It rather is octane bug, in other thread user named opstyix gave me workaround for displaying textures in viewport (because it’s not working as well) and it fixes frozen UVs problem too, adding blender texture node and blender output node, then setting UVs using eevee for preview and then when going back to object mode makes octane respects the new Uv layout
Of course it would be very painful to work like that all the time in normal projects, so I think I’ll stick to octane 4 as long as I can
Do You use 3.3 ? does material preview or texture preview work in 3.3?
dktw
Re: Uv not updating
Postby opstyix » Tue Sep 27, 2022 6:52 pm
opstyix Tue Sep 27, 2022 6:52 pm
Glad the workaround helped! Just wanted to chime in to say that the bug is also present in the latest Blender Octane Test build 2022.1.XB3 27.3 beta, which is based on Blender v3.3.2.
opstyix
Re: Uv not updating
Postby dktw » Tue Sep 27, 2022 9:00 pm
dktw Tue Sep 27, 2022 9:00 pm
Thanks for the info opstyix! I was curious about that :)
dktw
Re: Uv not updating
Postby linograndiotoy » Wed Sep 28, 2022 8:18 am
linograndiotoy Wed Sep 28, 2022 8:18 am
We'll fix this issue. Meanwhile, setting the Object Type to Reshapable should help.
linograndiotoy
Re: Uv not updating
Postby jan8 » Sun Oct 30, 2022 1:51 am
jan8 Sun Oct 30, 2022 1:51 am
I can confirm the same behavior in 2022.1 XB4 (blender 3.3.2) - lots of very odd and unexpected behavior around the UV editor, sometimes I have to delete cameras to get out of it, very disruptive for the workflow. (win10, 3080ti, nvidia 516.94)
jan8
Re: Uv not updating
Postby lizi45444966 » Thu Jan 12, 2023 9:23 am
lizi45444966 Thu Jan 12, 2023 9:23 am
I have a stupid but effective method, click on the object CTRL+A, select "Transform All", or right click, reset the origin, one of these two operations will always be useful, this is the method I discovered by accident. This bug has been around for a long time, and I'm annoyed that it's still not officially fixed.
lizi45444966
Re: Uv not updating
Postby linograndiotoy » Mon Jan 16, 2023 10:09 am
linograndiotoy Mon Jan 16, 2023 10:09 am
This should have been fixed already. I'll check, odd if it's still there.
linograndiotoy
Re: Uv not updating
Postby linograndiotoy » Mon Jan 16, 2023 10:51 am
linograndiotoy Mon Jan 16, 2023 10:51 am
Just checked and I can't reproduce the issue in latest 2022.
linograndiotoy
Return to Blender
Users browsing this forum: No registered users and 23 guests
Fri Apr 26, 2024 4:22 am [ UTC ]
