How to load UDIM texture?
Forums: How to load UDIM texture?
Postby kirk » Tue Jun 16, 2020 10:08 am
kirk Tue Jun 16, 2020 10:08 am
I recall Octane can do it, at least I once managed to do it somehow . Still it's almost unsolvable puzzle. Could somebody help please.
Q6600, 5GB ram, GF9800gt-1gb, 3dsMax 2008 , Blender , Zbrush, Messiah 3d v5, Terragen 2, Vue 6 Infinity
kirk
Re: How to load UDIM texture?
Postby J.C » Tue Jun 16, 2020 9:34 pm
J.C Tue Jun 16, 2020 9:34 pm
In Octane plugin for Blender there needs to be a special file naming:
Example with two rows and 4 columns:
00u-01v | 01u-01v | 02u-01v | 03u-01v
00u-00v | 01u-00v | 02u-00v | 03u-00v
System – Windows 11
J.C
Postby linograndiotoy » Wed Jun 17, 2020 4:05 pm
linograndiotoy Wed Jun 17, 2020 4:05 pm
Please refer to this example I made to better understand how UDIMs work in Blender:
viewtopic.php?f=114&t=74779&p=382801&hilit=udim#p382801
It will become easier as soon as we'll implement the possibility to use Octane Standalone node system directly in Blender.
linograndiotoy
Postby kirk » Thu Jun 18, 2020 12:09 pm
kirk Thu Jun 18, 2020 12:09 pm
Thanks J.C and linograndiotoy. So basically Octane is not working with typical UDIM and needs it's own naming convention?
No way it would read regular UDIM named files? like 1001,1002,1003 etc? Can standalone read them with some combination of % - etc? Renaming lots of files would be pretty tiresome
Does anyone know a conversion script or something?
kirk
Postby Midphase » Sat May 29, 2021 7:46 pm
Midphase Sat May 29, 2021 7:46 pm
I got it to work, and I'm posting the solution here for future users.
Basically there are several steps that need to be taken in order to get UDIMs to properly work in Octane for Blender:
1. Use the TextureTile node and not just the plain Texture node.
2. Replace the last 4 digits in the UDIM file name to "1%i". So for instance, let's say your file name is the following: SPACESHIP_BASECOLOR_1001.exr in order for Octane to recognize it you have to change it to SPACESHIP_BASECOLOR_1%i.exr (at least this is what is working for me)
3. Now you need to change the number or rows in the node Grid Size (X) and (Y) to 10 and 10 (the second number should be higher if you have more than 100 UDIM tiles to match your UDIM set.
4. Now you need to change the Start value in the Node parameter to 1 because UDIMs start at 1001
5. Double check that your Digits is set to 3 because Octane disregards the first digit so it's only looking at 001, 002, 003 etc.
That should do it.
In the meantime, I will point to this video that ultimately was what got me to the solution.
https://youtu.be/vnYznjQXd8E
Midphase
Return to Blender
Tue Jun 04, 2024 1:57 pm [ UTC ]
