Import .Obj in Octane Render?
Forums: Import .Obj in Octane Render?
Postby Interfaces » Fri May 23, 2014 6:58 am
Interfaces Fri May 23, 2014 6:58 am
hi all I would like to retrieve aef model (model Artlantis)
I export from obj file in Artlantis. I have a. mtl and a folder with the file contents, but when I import in octane render I have my 3d model with only one subject.
I test a model to export sketchup materials but also disappear.
I would like to retrieve an entire library of vegetation.
Do you have a solution?
thank you
Interfaces
Re: Import .Obj in Octane Render?
Postby TIG » Fri May 23, 2014 9:25 am
TIG Fri May 23, 2014 9:25 am
Read the start of the OBJ file in a test editor.
It shows the expected relative path to the MTL file - usually it's just the file name as it is in the same folder as the OBJ [e.g. "objname.mtl"].
Read the MTL file in a text editor.
It shows the expected relative paths for any image files used for textures, usually in a sub-folder that is kept with the MTL file [e.g. "Textures/leaf666.png"].
Ensure that the files and subfolder/images are correctly located relative to each other, and that the OBJ/MTL files correctly refer to the relative paths...
TIG
TIG
Postby Interfaces » Mon May 26, 2014 7:14 am
Interfaces Mon May 26, 2014 7:14 am
TIG thank you for your help. I can test. I inform you if it works.
I have a request for better visibility forum for new come example:
would be possible to put the valid plugin at the top of the list
see example:
THANKS.
Interfaces
Return to SketchUp
Who is online
Users browsing this forum: No registered users and 20 guests
Fri Apr 26, 2024 6:12 am [ UTC ]
