Color Shader defeated by Cloth Surface
Forums: Color Shader defeated by Cloth Surface
Moderator: aoktar
Postby pcoombes » Tue Apr 16, 2024 4:15 am
pcoombes Tue Apr 16, 2024 4:15 am
Windows 11 Folds.zip
(242.04 KiB) Downloaded 7 times
Hi
Don't know if this is a bug or user error, but the Cloth Surface generator doesn't respect the Color Shader I've applied to the child Cloner object.
I was trying to create the windows 11 background using a cloner and some cloth discs, but the shader doesn't work with the Cloth Surface generator.
If you toggle on and off the Cloth Surface generator in the attached file you'll see the problem.
This is using C4D 2024.4.0 and Octane 2023.1.2-(R7)
Cheers
pcoombes
Re: Color Shader defeated by Cloth Surface
Postby bepeg4d » Tue Apr 16, 2024 7:09 am
bepeg4d Tue Apr 16, 2024 7:09 am
try to make the Cloth Surface parent of the disk, not of the Cloner:
ciao,
Beppe
Postby pcoombes » Tue Apr 16, 2024 10:29 pm
pcoombes Tue Apr 16, 2024 10:29 pm
Thanks Beppe.
It works, but sadly doesn't let you alter the Cloth subdivision after the sym is cached. Oh well.
pcoombes
Postby jayroth2020 » Tue Apr 16, 2024 10:36 pm
jayroth2020 Tue Apr 16, 2024 10:36 pm
Use an Octane Object Tag and set your subdivision with that instead. It will add SubDs at rendertime on the GPU.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Postby bepeg4d » Wed Apr 17, 2024 6:58 am
bepeg4d Wed Apr 17, 2024 6:58 am
the issue is that the Disk topology is not good for deformations, but you can use a Remesh tool to have a perfect quad mesh that doeesn't have issues in deforming:
ciao,
Beppe
Postby pcoombes » Wed Apr 17, 2024 8:40 pm
pcoombes Wed Apr 17, 2024 8:40 pm
Thanks guys.
#jayroth2020 The Cloth generator is also providing thickness to the geometry, which the Octane Object tag doesn't provide.
#beppe The disc has a non-zero internal diameter, so the geometry is all quads already. Unless C4D is doing something internally that isn't displayed.
pcoombes
Postby jayroth2020 » Wed Apr 17, 2024 8:49 pm
jayroth2020 Wed Apr 17, 2024 8:49 pm
You can still use the Octane Object tag for your Subdivision; just disable the sudivision on the Cloth Generator...
jayroth2020
Postby pcoombes » Wed Apr 17, 2024 10:22 pm
pcoombes Wed Apr 17, 2024 10:22 pm
It's more about the Color Shader node not randomising the colour once the Cloner is put under the Cloth Generator, rather than a subdivision issue.
Somewhat resolved the problem by using a Tube object, with an Octane Object Tag for the subdivision. The sim runs slower, which is a pain, but it gets what I want.
pcoombes
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 15 guests
Tue Apr 30, 2024 9:46 am [ UTC ]
