hi, i am using C4D R25 on a MacBook Air M2, Monterey
I installed both 2023.1.2-R3 and 2024.1 Alpha2 - R3, but neither of them worked
Is my setup compatible? Thanks
Moderator: aoktar
aoktar wrote:These versions require the Sonoma if I could remember correct it!
bepeg4d wrote:Hi,
for 2023.1 versions, you need to have macOS 13.3 or higher.
We strongly recommend that you update macOS to version 13.3 or greater.
Prior to 13.3, there is an OS related issue that causes a render failure consistently if you render for long periods of time.
For 2024.1 versions, you need to have macOS Sonoma 14.1 or greater.
ciao,
Beppe
Users browsing this forum: Aymeric_FX, Google [Bot] and 12 guests
