Environment map randomly not loading
Forums: Environment map randomly not loading
Moderator: aoktar
Postby brutesque » Fri Dec 15, 2023 2:02 pm
brutesque Fri Dec 15, 2023 2:02 pm
I'm rendering with team render. I have a file that contains about 10 takes. I'm sending all the takes to the Team Render Queue. All the takes are using the exact same assets. But 30% of my queue will have not loaded the environment map and will have rendered black frames (since i have no other light sources). At this point rendering with Octane is a gamble wether the renders are gonna be ok. My scenes are super super small and simple, i'm just rendering some spline extrudes, nothing fancy. I can see in the team render client log that the asset was successfully loaded.
The team render machine is using c4d 2024.1.0 and 2024.2.0 and OctaneRender 2023.1
brutesque
Re: Environment map randomly not loading
Postby aoktar » Fri Dec 15, 2023 9:45 pm
aoktar Fri Dec 15, 2023 9:45 pm
I believe that you made same post on other topic and I replied you, isn't?
viewtopic.php?f=30&t=82222&sid=8d6dd0b3943a43f37b2ec204a706228a#p429969
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 8 guests
Wed May 22, 2024 7:43 am [ UTC ]
