Color shader goes wrong
Forums: Color shader goes wrong
Moderator: aoktar
Postby firesprite » Wed May 18, 2022 8:40 pm
firesprite Wed May 18, 2022 8:40 pm
ok, here is the link to simple test scene with morphing objects and change their colors using mograph and fields:
https://www.dropbox.com/s/fkjunodo1d3xl ... t.c4d?dl=0
I investigated that scene rendering wrong in all 2021.1.4 and newest 2021.1.5 builds.
But 2021.1.3 and experimental version 2022.1-XB0_R1 working good.
That's mean all present versions for R26 working with bugs.
firesprite
Re: Color shader goes wrong
Postby aoktar » Wed May 18, 2022 9:35 pm
aoktar Wed May 18, 2022 9:35 pm
what's the reason of using a cloner with just one clone under another cloner?
Postby firesprite » Thu May 19, 2022 12:06 am
firesprite Thu May 19, 2022 12:06 am
aoktar wrote:what's the reason of using a cloner with just one clone under another cloner?
child cloner work in blend mode and controlled by plane effector for morphing from one object to other.
parent cloner used for cloning first one through surface, in this case cube.
this is old trick and i've been used it many times in my projects, but with new octane builds color shader begin working incorrectly, pleeease fix it
firesprite
Postby aoktar » Thu May 19, 2022 7:08 am
aoktar Thu May 19, 2022 7:08 am
It's working well if you connect effector to top cloner. I'm not sure it was like as you say before. I may be corrupting something while trying to fix something else if so.
Postby firesprite » Thu May 19, 2022 4:17 pm
firesprite Thu May 19, 2022 4:17 pm
I recorded video how it's working on my machine:
https://www.dropbox.com/s/fscqd3sr0v5ax ... 6.mp4?dl=0
for sure I've try applied material on parent cloner, but it doesn't help(
firesprite
Postby aoktar » Thu May 19, 2022 8:18 pm
aoktar Thu May 19, 2022 8:18 pm
Yes you're right! It doesn't correctly work in case. I'm trying to bring better mechanism to calculate it well.
Postby firesprite » Fri Jun 03, 2022 4:19 pm
firesprite Fri Jun 03, 2022 4:19 pm
New Octane version for C4d 2021.1.5-R2 still works incorrect((
firesprite
Postby aoktar » Fri Jun 03, 2022 8:42 pm
aoktar Fri Jun 03, 2022 8:42 pm
firesprite wrote:New Octane version for C4d 2021.1.5-R2 still works incorrect((
I know, I'm not able to fix it. Pretty hard to do. You'll read from notes if it's done
Postby firesprite » Thu Aug 24, 2023 6:35 pm
firesprite Thu Aug 24, 2023 6:35 pm
Hi Aoktar,
i'm returning back with the same question after 1,5 years since this topic has been started. And the color issue is still did not fixed unfortunately (
firesprite
Return to Maxon Cinema 4D
Users browsing this forum: Bing [Bot] and 18 guests
Sat Apr 27, 2024 12:32 am [ UTC ]
