Network Rendering Help with Octane X with and PC as slave
Forums: Network Rendering Help with Octane X with and PC as slave
Moderator: aoktar
Postby lextrickett » Fri Mar 18, 2022 6:34 am
lextrickett Fri Mar 18, 2022 6:34 am
Hi There,
Is it possible to use a m1 pro macbook pro as a main render machine (Using Octane X PR13, R25.117) with a PC - using 2021.1.3 as a render slave (3080ti)
Which versions of Octane speak to one another between Mac and PC?
My network rendering is currently active on port 48000 on the mac and the pc is visible in network preferences its just sayting - invalid version (11.00.3 [0])
Is there anything i can do? Any help would be greatly appreciated.
Thank you
lextrickett
Re: Network Rendering Help with Octane X with and PC as slave
Postby bepeg4d » Fri Mar 18, 2022 7:32 am
bepeg4d Fri Mar 18, 2022 7:32 am
No sorry, it is not possible to mix Metal and CUDA render-nodes for network rendering yet, but we are almost there.
OctaneX is still based on 2020.1.5 SDK, with some addictions, while PC version is at 2021.1.3 SDK.
We need to wait for the next upcoming 2022.1 SDK, to have an OctaneX version based on the same SDK as CUDA, and to be able to experiment Net render in a mixed environment, with both CUDA and Metal Render-Nodes.
Stay tuned...
ciao,
Beppe
Postby rgbjoy » Sat Dec 17, 2022 12:19 am
rgbjoy Sat Dec 17, 2022 12:19 am
Is this possible yet with 2022?
rgbjoy
Postby bepeg4d » Mon Dec 19, 2022 8:18 am
bepeg4d Mon Dec 19, 2022 8:18 am
No, sorry again, not yet.
But now that we finally have the same SDK with 2022.1, for both Windows and macOS Apple Silicon M1/M2, the core devs are working on network rendering and headless rendering options (it will be possible to add a Mac Pro with AMD GPU, or PC with Nvidia GPU as if it were an eGPU - connected to an M1/M2 mac or iPad Pro M1/M2), for upcoming 2023.1 SDK.
ciao,
Beppe
Postby fibernaut » Thu May 04, 2023 10:23 am
fibernaut Thu May 04, 2023 10:23 am
Hi Beppe,
any news on this HOT TOPIC?
Cheers
Win 10 64 | 2x RTX 3080Ti 2x Xeon E5 2650v2 Supermicro X9DAi 128 GB
Win 10 64 | 1x RTX 4090 i9 9900K Gigabyte z390 128 GB
Win 10 64 | 2x RTX 3080Ti i7 2600 K 32 GB
fibernaut
Postby Delizade » Sun Mar 03, 2024 9:43 pm
Delizade Sun Mar 03, 2024 9:43 pm
hi,
I was trying to use my pc for network rendering from mac but I can't reach to the network rendering settings page from mac-cinema4d. I guess that is still not working like you said in your first post here?
Windows 10 (3090Ti) | MacBook Pro (M3 Max)
Delizade
Postby bepeg4d » Mon Mar 04, 2024 8:27 am
bepeg4d Mon Mar 04, 2024 8:27 am
Hi guys,
multi platform Network Rendering is now possible, but you need to install c4doctane 2024.1-Alpha3 Metal version on M1/M2/M3 under macOS Sonoma:
viewtopic.php?f=85&t=83085
And the corresponding Render-Node version for Windows or Linux that you can find here:
viewtopic.php?f=33&t=83054
Have a look at this speed test here:
viewtopic.php?f=7&t=75411&start=1580#p430565
ciao,
Beppe
Postby Delizade » Tue Mar 05, 2024 12:41 am
Delizade Tue Mar 05, 2024 12:41 am
Hi bepeg4d,
I've done all of those steps and this is a miracle! It works perfectly.
Thank you all!
By the way, a side question: My Windows machine is set to sleep after half an hour of idle time. However, it still goes to sleep while the GPU is being used. Does anyone know how I can prevent Windows from sleeping while the GPU is being used?"
Delizade
Return to Maxon Cinema 4D
Users browsing this forum: pxlntwrk and 23 guests
Sun Apr 28, 2024 8:35 am [ UTC ]
