Bake texture as an image sequence
Forums: Bake texture as an image sequence
Moderator: aoktar
Postby gifmotion » Fri Oct 22, 2021 5:30 am
gifmotion Fri Oct 22, 2021 5:30 am
Could it be possible to create a 'bake texture as image sequence for the Bake Texture node in c4d? Because I'm using a c4d animated noise and although it works in rendering 'Reseond all scene data' in the render settings. Which causes instability at times.
Dean
gifmotion
Re: Bake texture as an image sequence
Postby aoktar » Fri Oct 22, 2021 8:24 am
aoktar Fri Oct 22, 2021 8:24 am
It should work with default settings. Why it works just with that? It's Deprecated option and doesn't support several features.
Postby gifmotion » Sat Oct 23, 2021 12:30 am
gifmotion Sat Oct 23, 2021 12:30 am
It works by default but I find that sometimes I need to enable 'Resend all scene data' in the render settings. Otherwise, the animated noise that is plugged into the baked texture does not update.
I've also found that if I want use any 'multiplies', 'add', 'color-correction etc nodes in the HDRI environment that it also needs to go into a 'bake texture node'
It would be great if the 'bake texture' node could also have a 'save texture as' area? And even better if it could somehow be done for animated sequences?
Dean
gifmotion
Return to Maxon Cinema 4D
Who is online
Users browsing this forum: Bing [Bot] and 14 guests
Wed May 01, 2024 10:34 am [ UTC ]
