Vectron slider value problem
Forums: Vectron slider value problem
Moderator: aoktar
Postby chrislavelle » Fri Sep 03, 2021 8:58 am
chrislavelle Fri Sep 03, 2021 8:58 am
Whilst using Vectron I have the following issue.
If i initiate Vectron all is good.
See the video link below for further info however i will also describe the issue.
https://vimeo.com/597080638
pass=vec
The problem:
If i use the sliders to change the parameters even the slightest movement will make the value jump from its original state (say a value of 10) to the hundreds of thousands. This means i cannot control the parameters via the sliders.
So if i have a power of 8 and i try to move it only a millimetre to move to a power value of 10, it jumps to a huge number.
Any assistance appreciated.
Chris
chrislavelle
Re: Vectron slider value problem
Postby ShivaMist » Mon Sep 13, 2021 10:24 am
ShivaMist Mon Sep 13, 2021 10:24 am
Hello!
You can modify the code and specifiy in and out values like so :
ShivaMist
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 37 guests
Fri Apr 26, 2024 6:01 pm [ UTC ]
