Shadow look too spread and too intense
Forums: Shadow look too spread and too intense
Moderator: aoktar
Postby bertritude » Thu Jun 15, 2017 6:02 am
bertritude Thu Jun 15, 2017 6:02 am
I'm working on a tracking 3D test and I use only a sun Hdri in C4D and compose all in after effects.
the shadow projected on the floor disk with octane matte material doesn't show the shadow nicely.
even if i desactive the sun, a full shadow covers the round ground.
I try to adjust all the light parameters, change kernels but result is the same.
How can I have a natural shadow whitch can fit the round ground ?
thanks
bertritude
Re: Shadow look too spread and too intense
Postby niestudio » Thu Jun 15, 2017 3:29 pm
niestudio Thu Jun 15, 2017 3:29 pm
Check out the ilifethrill breakdowns on render layer
https://vimeo.com/119848103
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
niestudio
Postby RSgraphics » Fri Jun 16, 2017 8:24 pm
RSgraphics Fri Jun 16, 2017 8:24 pm
niestudio wrote:Check out the ilifethrill breakdowns on render layer
niestudio, the link you provided is of an old version of Octane. I'm sure an experienced 3D artist with years of experience behind him can figure it out, but a new user/artist can't. Any tips on how to sort this out in Octane 3.0? Things seem to have been moved around a lot over the years.
OTOY, please provide updated tutorials to features. Please don't send me to the manual as it isn't all that clear either.
RSgraphics
Postby bepeg4d » Sat Jun 17, 2017 6:26 am
bepeg4d Sat Jun 17, 2017 6:26 am
Hi RSgraphics,
the Render Layer workflow has not changed between v2 and v3. The only difference from the vieotutorial is that the Render pass tab is no longe in the Octane Settings, but only in Render Settings/Octanerender/Render pass tab.
Happy rendering,
ciao beppe
Postby niestudio » Sat Jun 17, 2017 4:27 pm
niestudio Sat Jun 17, 2017 4:27 pm
RSgraphics wrote: Any tips on how to sort this out in Octane 3.0? Things seem to have been moved around a lot over the years.
As Beppe said. Yes, things have moved, but the technique remains.
Here is a basic scene similar to yours that should get you going if you look at this while watching the tutorial.
Shadow_Render_Layer.zip
(4.99 MiB) Downloaded 86 times
niestudio
Postby RSgraphics » Tue Jun 20, 2017 7:22 pm
RSgraphics Tue Jun 20, 2017 7:22 pm
Thank you, beppe and niestudio.
Yes, i'm aware that it moved, I'll do as niestudios suggests and try again with the help of his attachment.
Thanks again you guys.
RSgraphics
Postby RSgraphics » Thu Jun 22, 2017 3:09 am
RSgraphics Thu Jun 22, 2017 3:09 am
Well, i downloaded the file and followed along again. It seems my render passes, Black Shadows, Colored Shadows, dont show any data. My reflection pass shows the reflection but its embedded into the ground plane.
RSgraphics
Postby niestudio » Thu Jun 22, 2017 4:32 pm
niestudio Thu Jun 22, 2017 4:32 pm
check the discussion here: viewtopic.php?f=30&t=61166 to see if this helps you.
niestudio
Return to Maxon Cinema 4D
Users browsing this forum: Bing [Bot] and 22 guests
Fri Apr 26, 2024 10:13 am [ UTC ]
