problem with emmissive material
Forums: problem with emmissive material
Moderator: aoktar
Postby ArcaneParadigm » Fri Oct 03, 2014 12:53 pm
ArcaneParadigm Fri Oct 03, 2014 12:53 pm
I'm trying to create a emmissive material and it only works randomly for a second then wont work again
working
so same material - the one with the heavy yellow light is what I would expect
but
all i did was click on the material node and the emmission stopped working and i coulndt get it to work again
I tried blackbody and texture and it 99% doesnt work - only occasionally for a second will it emit
ArcaneParadigm
Re: problem with emmissive material
Postby aoktar » Fri Oct 03, 2014 12:59 pm
aoktar Fri Oct 03, 2014 12:59 pm
last will help to you
viewtopic.php?f=30&t=40997
also use arealight as possible as, if you cannot understand the concept.
Postby ArcaneParadigm » Fri Oct 03, 2014 1:03 pm
ArcaneParadigm Fri Oct 03, 2014 1:03 pm
It came back again but then I clicked on the material again and it stopped emitting light
Also notice I'm using a symmetry object to mirror the poles and lanterns and the glow is only on one side
so the emmission is not being transfered to the other side either
ArcaneParadigm
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 29 guests
Sun Apr 28, 2024 4:42 pm [ UTC ]
