Post porcessing issue
Forums: Post porcessing issue
Moderator: aoktar
Postby 62STARTREK » Wed Feb 08, 2023 5:10 pm
62STARTREK Wed Feb 08, 2023 5:10 pm
Hi all. As you can see in the pics below I have an issue with a rendering. I've activated the Post Processing settings (bloom effect) and in the Live Viewer it works, but in the final render (C4D system, not AOVs) it doesn't work. What am I doing wrong? Thanks
62STARTREK
Re: Post porcessing issue
Postby aoktar » Wed Feb 08, 2023 7:03 pm
aoktar Wed Feb 08, 2023 7:03 pm
What's render resolutions? Post effects are pixel size based. Not rational to dimensions as you can notify
Postby 62STARTREK » Wed Feb 08, 2023 7:36 pm
62STARTREK Wed Feb 08, 2023 7:36 pm
Thanks for the reply, the render settings are 1280x800, 72 DPI.
62STARTREK
Postby bepeg4d » Thu Feb 09, 2023 7:37 am
bepeg4d Thu Feb 09, 2023 7:37 am
Please enable the Lock icon in Live View, to have the same resolution as Picture Viewer.
Please also check to have enabled the Use denoised beauty pass option in Render Settings/OctaneRender/Main tab, thanks.
ciao,
Beppe
Postby 62STARTREK » Thu Feb 09, 2023 4:59 pm
62STARTREK Thu Feb 09, 2023 4:59 pm
Ciao Beppe, "Use denoised beauty pass" is checked but now there is another issue. If I lock the Live Viewer I have a crash. If I uncheck it the render starts but with same previous issue. Here's the log report
octanelog_report.zip
(12.05 KiB) Downloaded 30 times
62STARTREK
Postby bepeg4d » Fri Feb 10, 2023 7:19 am
bepeg4d Fri Feb 10, 2023 7:19 am
please upgrade Win 10 to 2004 or greater, then try again and report back, thanks.
ciao,
Beppe
Postby 62STARTREK » Fri Feb 10, 2023 2:30 pm
62STARTREK Fri Feb 10, 2023 2:30 pm
Hi, sorry but I don't undestand what 2004 means. The O.S. is automatically upgraded
62STARTREK
Postby jayroth2020 » Fri Feb 10, 2023 6:00 pm
jayroth2020 Fri Feb 10, 2023 6:00 pm
Beppe is referring to Windows build 2004 or greater.
CaseLabs Mercury S8 / ASUS Z10PE-D8 WS / Crucial 64GB 2133 DDR4 / 2 XEON E5-2687W v3 3.1 GHz / EVGA 1600 P2 / 1 EVGA RTX 3090Ti FTW3 Hybrid / 2 EVGA RTX 2080Ti FTW3 Hybrid/ Cinema 4D
jayroth2020
Return to Maxon Cinema 4D
Users browsing this forum: No registered users and 31 guests
Fri Apr 26, 2024 6:52 am [ UTC ]
