Octane crashing my computer
Forums: Octane crashing my computer
Moderator: aoktar
Postby Anim8me2 » Fri Nov 25, 2022 6:09 pm
Anim8me2 Fri Nov 25, 2022 6:09 pm
I have been hammering away at solving this and I can't fix it.
Running the latest stable build, As soon as I enable path tracing Octane will start pushing my GFX cards and kill the system. Screens go black and the fans go into overdrive.
This happens in 2023 or r26.
Every other render engine (Arnold and Redshift) works fine. It's just octane
Last log file attached.
System:
Threadripper 3070
128GB RAM
Dual rtx 3090
c4doctanelog.txt
(112.7 KiB) Downloaded 36 times
Anim8me2
Re: Octane crashing my computer
Postby bepeg4d » Sat Nov 26, 2022 8:13 am
bepeg4d Sat Nov 26, 2022 8:13 am
please perform a clean installation of 516.94 Nvidia Studio driver:
https://www.nvidia.com/download/driverR ... 969/en-us/
To perform a clean installation, please follow these steps:
Then please, after reboot, download and run OctaneBench 2020.1, and share a complete screenshot of the result, thanks:
https://render.otoy.com/downloads/a/61/ ... _5_win.zip
ciao,
Beppe
Postby Anim8me2 » Sat Nov 26, 2022 10:28 pm
Anim8me2 Sat Nov 26, 2022 10:28 pm
I installed the suggested driver, rebooted and ran Octanebench. I get the same result. As soon as Octanebench reaches the path-tracing section the machine crashes.
Anim8me2
Postby elsksa » Sat Nov 26, 2022 10:36 pm
elsksa Sat Nov 26, 2022 10:36 pm
A crash often relates to a hardware failure. It would be suggested to look at hardware level (motherboard & PSU connections, properly powered components, etc).
elsksa
Postby Anim8me2 » Sun Nov 27, 2022 3:39 am
Anim8me2 Sun Nov 27, 2022 3:39 am
I would agree, it as I stated octane is the only rendering engine that is causing this. I have tried it with Arnold as well as Redshift and Cycles and none of them have this issue. I can even push large scenes through Clarisse and I have no problems.
Anim8me2
Postby bepeg4d » Sun Nov 27, 2022 8:24 am
bepeg4d Sun Nov 27, 2022 8:24 am
If also OctaneBench is crashing, the system seems not quite stable to me :roll:
Ok, please try to go to Nvidia Control panel, menu Help, and enable the Debug mode, to work with GPUs at default clock, and run again OctaneBench:
ciao,
Beppe
Postby elsksa » Sun Nov 27, 2022 12:01 pm
elsksa Sun Nov 27, 2022 12:01 pm
Anim8me2 wrote:I would agree, it as I stated octane is the only rendering engine that is causing this. I have tried it with Arnold as well as Redshift and Cycles and none of them have this issue. I can even push large scenes through Clarisse and I have no problems.
Octane is a GPU renderer, among all the ones you've mentioned, only RS is one (natively and originally). Unless you are on Clarisse Angie which is not yet a stable hybrid renderer, or Cycles GPU/forked GPU version.
If Octane is causing the crash, it would usually imply that it is triggering an issue that the others don't.
Further troubleshooting is definitely required. Do keep us updated.
elsksa
Postby Anim8me2 » Mon Nov 28, 2022 1:48 pm
Anim8me2 Mon Nov 28, 2022 1:48 pm
elsksa wrote:A crash often relates to a hardware failure. It would be suggested to look at hardware level (motherboard & PSU connections, properly powered components, etc).
I have checked every component and reseated all cables. I have also unplugged one of my graphics cards to remove power draw on the system, but the issue persists. I have also tried using the Octane version of Blender and it works without crashing. C4d and Octanebench still crash.
Anim8me2
Postby elsksa » Mon Nov 28, 2022 3:52 pm
elsksa Mon Nov 28, 2022 3:52 pm
Which PSU?
What does the the crash log says? If anyone has been able to have a look, as I can't open it.
elsksa
Postby Anim8me2 » Mon Nov 28, 2022 7:24 pm
Anim8me2 Mon Nov 28, 2022 7:24 pm
elsksa wrote:Which PSU?
Corsair AX1600i
Anim8me2
Next
Return to Maxon Cinema 4D
Users browsing this forum: Aszyk and 43 guests
Fri Apr 26, 2024 9:11 am [ UTC ]
