Camera ?
Forums: Camera ?
Re: Camera ?
Postby Alul » Fri Feb 25, 2011 6:20 pm
Alul Fri Feb 25, 2011 6:20 pm
Have you try to render animation?
Alul
Re: Camera ?
Postby face » Sat Feb 26, 2011 5:18 am
face Sat Feb 26, 2011 5:18 am
I haven´t tryed it because in your scene the keyframed camera z-rotation is, with one exception, 0.
Before i test it, maybe that is the issue?
If no, i can make some keys on the z-rotation and render it.
face
http://vimeo.com/user2509578
face
Re: Camera ?
Postby Alul » Sun Feb 27, 2011 11:51 pm
Alul Sun Feb 27, 2011 11:51 pm
I was useing fancy new autdesk feature keyframe camera. You know does two "new" buttons in camera property ppg. Its picking some animation channels to key camera movement. I know that rot.y is not changing but still its something wrong. I was also checking upvector of camera rig. I'm just saying that, there is a diffidence in camera rotation between frame (i.e. 9) when you render it as one frame and when you render in as "animation".
Anyway i will double check if what can be wrong at SI side.
Alul
Re: Camera ?
Postby face » Mon Feb 28, 2011 1:28 am
face Mon Feb 28, 2011 1:28 am
Hm, i have render it as single and I have render it as animation from frame 8 to 9.
At frame 9, I have the same up-vector, with the still and the animation, for the camera. (x=-0.0786038, y=0.9823382, z=0.1698030)
Can´t find any issue at this time, it´s seems a little bit tricky :|
But i´ve seen that you use not the current version of the plugin or you haven´t update the custom parameter in the scene.
The native unit size is missing in the Project configuration tab.
You can find it here:
http://www.refractivesoftware.com/forum/viewtopic.php?f=29&t=4393&start=0
face
face
Previous
Users browsing this forum: No registered users and 23 guests
Sat Apr 27, 2024 7:34 pm [ UTC ]
