hair...still can not render?
Forums: hair...still can not render?
Re: hair...still can not render?
Postby face » Thu Nov 06, 2014 7:26 pm
face Thu Nov 06, 2014 7:26 pm
e880291 wrote:this is very cool
and I still have last two question(still the hair question)
even I use this way(use ICE make fur or hair)
how can I control the texture of all the skin(like...tiger or.Zebra),and the color map of root to tip? :D :D :D
thank you,Face
The particles or strands are only working with instance shapes.
This instances can have one uv texture which you can use to color the root to tip as example.
If the instance havent a texture, the ICE color is used. You can also read in a texture from the emitted mesh and use this to drive the ICE color value. So you can emulate a zebra look.
The combination of both isn´t possible because only one texture per mesh can be used with Octane.
face
http://vimeo.com/user2509578
face
Postby e880291 » Sat Nov 08, 2014 5:39 am
e880291 Sat Nov 08, 2014 5:39 am
yes, I got it
I see the video link , but I don't understand how to bake the texture map from Ice (instance) to the *obj?
I decide to give up the"color the root to tip "
but I stll needs the fur texture like tiger or zebra ....hahaha
thank you so much))
e880291
Postby face » Sat Nov 08, 2014 9:15 am
face Sat Nov 08, 2014 9:15 am
As example you create a grid, then apply a texture map on it via Property->Texture Map->XZ.
This can be used in the Render Tree and can read in into an ICE Tree like in the scene file below.
strands.zip
Softimage 2013 Scenefile
(275.65 KiB) Downloaded 621 times
Then apply an instance shape to it. This shape shouldn´t have a texture projection.
For performance and if you dont want to export it, you can hide the instance shape.
If you turbulize the strands, the instance shape should have the same subdivisions on y like the strandsegments -1.
The shape should also lie on 0,0,0.
Remember, more segments will increase the export time.
Hope this helps a little bit,
face
face
Previous
Fri Apr 26, 2024 11:14 am [ UTC ]
