some objects triangulate not work in octane why?
Forums: some objects triangulate not work in octane why?
Postby Destrankir » Tue Mar 13, 2012 2:45 pm
Destrankir Tue Mar 13, 2012 2:45 pm
softimage
octane render
Destrankir
Re: some objects triangulate not work in octane why?
Postby t_3 » Tue Mar 13, 2012 3:01 pm
t_3 Tue Mar 13, 2012 3:01 pm
its a problem with the normals. if you turn smoothing off, you will see plane surfaces, but of course still no round shape (assuming that is what you want). you need to realign the normals. imo in general it is better to not triangulate objects if possible...
t_3
Postby face » Tue Mar 13, 2012 4:40 pm
face Tue Mar 13, 2012 4:40 pm
The normals looks also incorrect on the wireframe. Have a look at the yellowish part.
You can use the Discontinuity slider under the Polygon Mesh tab in the Geometry Approximation PPG to change the angle to a value which looks good, normal 60°.
60° means, if a angle between two polygon normals are lesser as 60°, the edges are blended together, greater, the edges are hard.
Polygons are in this case triangles...
face
http://vimeo.com/user2509578
face
Postby Destrankir » Wed Mar 14, 2012 10:14 am
Destrankir Wed Mar 14, 2012 10:14 am
Tanks finally i have some normals and some Geometry Approximation bad xD
Destrankir
Sat May 11, 2024 6:44 pm [ UTC ]
