How to animate lights (color\temperature, power etc.)
Forums: How to animate lights (color\temperature, power etc.)
Autodesk Softimage XSI (Developed by Face)
Postby Alul » Mon Dec 05, 2011 7:50 pm
Alul Mon Dec 05, 2011 7:50 pm
Hi all. Does anyone have an idea how to animate light temperature? Or how to animate IES spread( scale) ? Thanks for any help.
... i bet there is a way do this..
Alul
Re: How to animate lights (color\temperature, power etc.)
Postby face » Mon Dec 05, 2011 8:13 pm
face Mon Dec 05, 2011 8:13 pm
You can use the texture emission.
Plug in this a generated image from a rendermap and you can animate the color.
Inside Softimage, you must then animate the color how you like. Best is to use a constant shader where you animate the color over time.
The rendermap will then render out the result and overwrite an existing image so the the imagename is for every frame the same.
The scale can´t animated because there is no conversation from a color to a float/scalar which can be used as input for the scale value.
Here is a rendermap tutorial for Octane:
http://vimeo.com/25573392
face
http://vimeo.com/user2509578
face
Postby Alul » Tue Dec 06, 2011 12:06 am
Alul Tue Dec 06, 2011 12:06 am
Do i have to pre-render sequence with rendermap? or this is automated with your plugin? I didn't tried yet but i want to ask before. Just to clarified it.
If I want to make some kind of videowall\tvscreen as a light source what should do the same ?
Alul
Postby face » Tue Dec 06, 2011 1:15 am
face Tue Dec 06, 2011 1:15 am
You must rename the RenderMap in OctaneMap, then the plugin will find it and fired the command to render the map, before the frame is rendered in Octane.
But you must first use the render frame button, so that an image is created which you can use in Octane to setup your materials.
When your materialsetup is complete, you can render the animation.
You can use the rendermap to bake every mentalray shader to the exported mesh, also an tv or similar.
The name of the image is derived from the meshname+rendermap, shown in the video...
face
face
Postby Alul » Thu Dec 22, 2011 12:24 pm
Alul Thu Dec 22, 2011 12:24 pm
Thank You face.
Alul
Return to Autodesk Softimage XSI
Who is online
Users browsing this forum: No registered users and 20 guests
Sat Apr 27, 2024 11:47 pm [ UTC ]
