specular glass and motion blur = flicking
Forums: specular glass and motion blur = flicking
Moderator: JimStar
Postby AdrienG » Sun Aug 20, 2023 9:39 pm
AdrienG Sun Aug 20, 2023 9:39 pm
Motion blur causes flickering in complex specular material (glass simple, no scatter).
No motion blur (shutter speed = 0) and no more problem.
Which parameter to deal with to get rid of this flicking ? i d like to keep the mb effect, or at least understand better.
Cheers
AdrienG
Re: specular glass and motion blur = flicking
Postby BK » Mon Aug 21, 2023 1:55 am
BK Mon Aug 21, 2023 1:55 am
AdrienG wrote:Hi,
Cheers
Hi Adrien,
Thank you for the post.
Have you tried increasing the **Samples Per Frame** from the Vertex animated mesh>Shape node>AE editor>Octane Rollout.
Would you please share a sample scene for us to investigate if this does not fix?
cheers
Kind Regards
bk3d
BK
Postby AdrienG » Mon Aug 21, 2023 8:39 am
AdrienG Mon Aug 21, 2023 8:39 am
thanks for your answer, i will try your recommandation now.
However, the deactivation of motion blur work seemed to attenuate the flickering on one shot but absolutely not on other shots.
See attachment video.
cheers
AdrienG
Postby AdrienG » Mon Aug 21, 2023 9:35 am
AdrienG Mon Aug 21, 2023 9:35 am
Ok i found the problem, very simple.
There's an overlap or very close distance between the specular mesh and a solid diffuse base/fixation.
Adding some distance between them fixed it. RayEpsilon could have been an other parameter to deal with i guess if there's any existing gap.
AdrienG
Postby elsksa » Mon Aug 21, 2023 2:10 pm
elsksa Mon Aug 21, 2023 2:10 pm
Ray Epsilon is global, it’s rarely needed, typically when the scene scale has been wrongly setup, is small or large due to the context. It’s a common misconception to think of RE as some sort of magic tweak that fixes user-errors.
elsksa
Return to Autodesk Maya
Users browsing this forum: No registered users and 20 guests
Sun Apr 28, 2024 4:44 pm [ UTC ]
