Hair material specular
Forums: Hair material specular
Moderator: JimStar
Re: Hair material specular
Postby visionmaster2 » Fri Nov 06, 2020 3:01 am
visionmaster2 Fri Nov 06, 2020 3:01 am
Thank your for the file !
it's really close to what i need :)
i can see that you changed the the roughness and the Azimuthal roughness.
Did you changed something else ?
when i put your material to my scene (with the light from the ForM2 file) the hair are still to white.
thank you
M.°
visionmaster2
Postby BK » Fri Nov 06, 2020 3:52 am
BK Fri Nov 06, 2020 3:52 am
visionmaster2 wrote:Thank your for the file !
thank you
M.°
Hello M,
Thank you again!! I guess both the Roughness value was low in the previous samples.
We did not change apart from that.
Is it possible to PM the Hair and the light only for us to look again?
Cheers
Kind Regards
bk3d
BK
Postby visionmaster2 » Fri Nov 06, 2020 4:14 am
visionmaster2 Fri Nov 06, 2020 4:14 am
Thank you for your Help !
the file must be in your Box now.
Merci beaucoup :)
visionmaster2
Postby BK » Mon Nov 09, 2020 5:07 am
BK Mon Nov 09, 2020 5:07 am
visionmaster2 wrote:Thank you for your Help !
Merci beaucoup :)
Hi M,
Thank you so much.
cheers
Kind Regards
bk3d
BK
Postby visionmaster2 » Tue Dec 01, 2020 8:25 pm
visionmaster2 Tue Dec 01, 2020 8:25 pm
Thank's to you and the devs !
M.°
visionmaster2
Previous
Return to Autodesk Maya
Users browsing this forum: No registered users and 13 guests
Fri Apr 26, 2024 6:14 pm [ UTC ]
