Hi!
How can I mix to textures with png file? I tried octane alpha image and octane image in amount of octanemixtexture and no sucess.
Thanks!
Tharso wrote:Hi!
calus wrote:Tharso wrote:Hi!
I'm not sure what you want to do exactly, is it using a greyscall png image as mask between 2 procedural texture to mix ?
or do you want to use the alpha in the png as a mask ?
or you want to mix 2 png ?
calus wrote:well, that's it,
you just have to use an "alpha image texture" node, load the png in it, then plug the "out tex" in the "amount" of the "mix texture" node.
If this doesn't work there might be a problem with the alpha of the png, did you check it ?
Tharso wrote: Can you confirm that is working fine in the last version of mayaplugin?
Users browsing this forum: No registered users and 10 guests
