Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
CHANGES AND FIXES SINCE LAST RELEASE:
- New 1.14 engine. The big amount of critical changes in this engine, so report please if you will encounter something broken in comparison to previous versions - I will fix it as soon as possible...
- Now the plugin does not have explicit "Null emission" node (it is redundant entity and has been deprecated in the last Octane engine versions).
- Fixed the movable proxy animation bug (calus reported).
- Made the workaround to stop the engine crashes between the frames during long batch animation renderings (sampakinpa reported).
- Fixed progress window issue when using python command "maya.cmds.octane(render=True, layer=layer_name)" (tailorstore reported).
- Minor bug fixes...
DOWNLOAD
OctaneRender for Maya v1.14 beta (35.5MB autoinstaller file)
Yours,
The OctaneRender™ Team.
