OctaneRender for Maya 2021.1.5 Installer hangs
Forums: OctaneRender for Maya 2021.1.5 Installer hangs
Moderator: JimStar
Postby iknowmedia » Thu Jun 23, 2022 7:29 am
iknowmedia Thu Jun 23, 2022 7:29 am
Hi All,
It seems that I cannot install the Octane for Maya plugin. It stops at "Extract: octaneRenderer.xml".
I run at administrator, disabled virus scanner, disabled firewall, reboot computer nothing works.
I can extract the installer archive and see the files so is there documentation to install this manually?
Or someone has some other tips?
Thx
Windows 7 | Q9550 @2833Mhz | 8GB | Zotac GTX480
iknowmedia
Re: OctaneRender for Maya 2021.1.5 Installer hangs
Postby iknowmedia » Thu Jun 23, 2022 8:45 am
iknowmedia Thu Jun 23, 2022 8:45 am
Weird, 2021.1.5 - 20.18 is installing fine.
iknowmedia
Postby itsallgoode9 » Mon Jun 27, 2022 5:32 pm
itsallgoode9 Mon Jun 27, 2022 5:32 pm
same issue for me. running on windows 10 x64
Intel i7-3930K, 64gb RAM, Asus X79 Deluxe mobo, 2x EVGA 780 6gb (for rendering), 1x PNY quaddro k4000 (for display)
Windows 8.1 x64, Maya 2014, Octane Render v2
itsallgoode9
Postby BK » Mon Jun 27, 2022 10:34 pm
BK Mon Jun 27, 2022 10:34 pm
iknowmedia wrote:Hi All,
Thx
Hi iknowmedia,
Thanks for the post. We are unable to replicate this on our end!
Would you please let us know which Autodesk Maya version you are trying to install OFM?
Anyway, please try the steps below to install the OFM manually after extracting!
- copy the OctaneRender VR for Maya or OctaneRender VRE for Maya folder under Program Files or anywhere in the drive!
- then extract the octane.mod file from
octanemod.zip
(323 Bytes) Downloaded 147 times
C:\Program Files\Autodesk\Maya20XX\modules
- open the octane module file in a text editor and change the first line
+ MAYAVERSION:20XXOctaneRender 20.19 C:\Program Files\OctaneRender VR/VRE for Maya\20XX
Please let us know how it goes!
cheers
Kind Regards
bk3d
BK
Postby iknowmedia » Tue Jun 28, 2022 12:00 pm
iknowmedia Tue Jun 28, 2022 12:00 pm
I installed 20.18 that worked for me. I use Maya 2022.3
iknowmedia
Postby BK » Wed Jun 29, 2022 4:27 am
BK Wed Jun 29, 2022 4:27 am
iknowmedia wrote:I installed 20.18 that worked for me. I use Maya 2022.3
Hi iknowmedia,
Thank you for the info.
We have the same Maya 2022.3 update and OFM 20.19 installed correctly in both Studio and Enterprise builds.
Is Autodesk Maya 2023 installed in C:\ drive or a different drive? also, please try installing manually and see if it resovles.
cheers
Kind Regards
bk3d
BK
Return to Autodesk Maya
Users browsing this forum: No registered users and 18 guests
Fri Apr 26, 2024 1:18 am [ UTC ]
