AOV render issue
Forums: AOV render issue
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
AOV render issue
Postby remKa » Thu Apr 25, 2024 9:20 pm
remKa Thu Apr 25, 2024 9:20 pm
Hello,
I have a scene with three custom AOV for three different materials, it works perfectly fine in the Octane Viewport but when I try to render a sequence with Max frame buffer, every AOV match the "custom AOV 1".
I've set each custom AOV with proper number in the render elements, please see the attached file : on the left Octane Viewport ported to the max frame buffer, on the right straight rendered from the Max frame buffer.
Thank you in advance
i7 3930K / 1 EVGA Titan Black SuperClocked - 1 GTX Titan - 1 GTX 960 / 32 Gb DDR 3
http://www.remka.fr
https://twitter.com/remKa_
remKa
Re: AOV render issue
Postby HHbomb » Sat Apr 27, 2024 2:26 pm
HHbomb Sat Apr 27, 2024 2:26 pm
Hi, have you try without changing AOV pass name ?
HHbomb
Postby remKa » Mon Apr 29, 2024 7:59 pm
remKa Mon Apr 29, 2024 7:59 pm
Yes, it doesn't work either
http://www.remka.fr
remKa
Postby neonZorglub » Mon Apr 29, 2024 10:35 pm
neonZorglub Mon Apr 29, 2024 10:35 pm
remKa wrote:Hello,
Hi remKa,
Thank you for reporting this issue.
I could reproduce the problem, that's right, the custom AOV number is not read correctly, and only AOV 1 will be saved..
Sorry about that, that will be fixed in the next release
neonZorglub
Postby remKa » Tue Apr 30, 2024 10:05 am
remKa Tue Apr 30, 2024 10:05 am
All right thank you :)
http://www.remka.fr
remKa
Return to Autodesk 3Ds Max
Users browsing this forum: Google [Bot] and 5 guests
Tue May 07, 2024 3:11 am [ UTC ]
