Multiple objects Groups or Assembly Octane Proxy export
Forums: Multiple objects Groups or Assembly Octane Proxy export
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby ofirgardy » Wed May 10, 2023 10:19 am
ofirgardy Wed May 10, 2023 10:19 am
What will be the proper way to export an Octane Proxy object that contains multiple objects (such as a group or assembly) if this is at all possible?
Or do I need to use 3ds Max's native Xref system?
Every time I try to export a selection of objects or a 'group' I end up either with multiple proxy files or just the first object of the 'group'.
Thanks for your help
ofirgardy
Re: Multiple objects Groups or Assembly Octane Proxy export
Postby paride4331 » Thu May 11, 2023 1:53 pm
paride4331 Thu May 11, 2023 1:53 pm
Hi ofirgardy,
I'm going to send my test to devs about the issue you reported.
paride4331
Postby paride4331 » Fri May 19, 2023 3:04 pm
paride4331 Fri May 19, 2023 3:04 pm
Hi ofirgardy,
Octane devs will work on this issue.
Currently, would be:
-select objects
-'Save Selected..." as .max eg 'furniturePack1_org.max'
[Steps to edit / re-export:]
open 'furniturePack1_org.max'
select all
-convert all the proxies with 'Replace original'
save as 'furniturePack1_prox.max'
Then, in the main scene, you can either load/merge it, or load/XRef
I hope it helps.
paride4331
Return to Autodesk 3Ds Max
Wed May 01, 2024 8:15 am [ UTC ]
