How to render Forest Pack ?
Forums: How to render Forest Pack ?
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby HHbomb » Mon Apr 12, 2021 9:57 am
HHbomb Mon Apr 12, 2021 9:57 am
I needed to render FP objects, I used to, but I can't anymore.
Fp object is set to "automatic", and octane to "direct"... not good ? All become very slow, sometimes it work, sometimes it loop form 0 to 1 sample...
I can't close rendering viewport window, and need to kill max.
Any advice ?
HHbomb
Re: How to render Forest Pack ?
Postby paride4331 » Mon Apr 12, 2021 3:53 pm
paride4331 Mon Apr 12, 2021 3:53 pm
Hi HHbomb,
I can't replicate your issue.
In order to test it, Could you share (in pm) your issued scene?
paride4331
Postby HHbomb » Tue Apr 13, 2021 8:27 am
HHbomb Tue Apr 13, 2021 8:27 am
Hi, Paride here is the scene with just forest pack.
With direct mode, render loop 0-1 sample. When the scene is very heavy ( lot of polys and maps ) , this loop inhibit to close octane render viewport render.
I tried all modes, but even legacy had problems.
What is the good workflow / settings ?
This problem was solved in previous version, and is back ?
to render my scene without problem I used Forest instancing tool... to remove FP and work with instances...
pb fp 2.zip
(5.48 MiB) Downloaded 142 times
HHbomb
Postby paride4331 » Tue Apr 13, 2021 8:57 am
paride4331 Tue Apr 13, 2021 8:57 am
HHbomb wrote:Hi, Paride here is the scene with just forest pack.
Hi HHbomb,
press Quick update mode in Octane viewport or "always enable Quick update" option in Octane preference > Viewport
paride4331
Postby HHbomb » Wed Apr 14, 2021 7:55 am
HHbomb Wed Apr 14, 2021 7:55 am
ahhhh ok. I forgot. :oops:
HHbomb
Postby HHbomb » Sat Apr 24, 2021 5:36 pm
HHbomb Sat Apr 24, 2021 5:36 pm
Hi again,
Yes with direct mode I can render FP, but sometimes I need to uncheck direct mode. Then, if I forget to check direct mode with a FP, in a big scene, Max freeze ( loop ) and I need to Kill Max... :evil:
HHbomb
Postby coilbook » Fri Apr 30, 2021 1:10 am
coilbook Fri Apr 30, 2021 1:10 am
HHbomb wrote:Hi again,
to speed up evaluation times I set to legacy mode otherwise octane rebuilds all itoo mesh every frame
coilbook
Postby mbetke » Fri Apr 30, 2021 8:04 am
mbetke Fri Apr 30, 2021 8:04 am
Yes it is not made very good. I always need to use legacy mode for ages now. Otherwise you will get problems with the loop issue.
Also, the Quick Mode doesn't work well sometimes.
iToo changed the SDK for other renderer with its Version 7, so it would be up to Otoy to include more compatibility and missing features into Octane.
PURE3D Visualisierungen
Sys: Intel Core i9-12900K, 128GB RAM, 2x 4090 RTX, Windows 11 Pro x64, 3ds Max 2024.2
mbetke
Postby HHbomb » Fri Apr 30, 2021 12:49 pm
HHbomb Fri Apr 30, 2021 12:49 pm
@coilbook
Yes legacy works, but you loose real time interaction with FP.
You should write a pre render script to set "forest pack support" to "legacy" and post one to "direct".
Or a maxscript with 2 buttons.
Or render with Vray or corona :-)
HHbomb
Postby coilbook » Thu Jun 03, 2021 7:36 pm
coilbook Thu Jun 03, 2021 7:36 pm
Hi PAride,
When using legacy itoo camera doesnt refresh. So if camera turns we have no grass. So now we stuck: quick legacy mode but no animated itoo or camera visibility or direct mode but eval times 30 sec per frame
coilbook
Next
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 20 guests
Fri Apr 26, 2024 4:47 pm [ UTC ]
