Can someone help me to understand all infos on render window
Forums: Can someone help me to understand all infos on render window
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby HHbomb » Wed Apr 07, 2021 10:57 am
HHbomb Wed Apr 07, 2021 10:57 am
Hi, there is more and more infos but I don't know what it means... :oops: ( see image below )
HHbomb
Re: Can someone help me to understand all infos on render window
Postby Creative_Sheep » Wed Apr 07, 2021 10:35 pm
Creative_Sheep Wed Apr 07, 2021 10:35 pm
Well some are your CPU, GPU Memory size, resolution of the render and estimated time it will take to complete the render.
Creative_Sheep
Postby HHbomb » Thu Apr 08, 2021 11:23 am
HHbomb Thu Apr 08, 2021 11:23 am
Thanks Creative_Sheep.
But I mean : (see pict)
rd: 19/32
new: 39
cop: 33
disc: 6
conv: 33
blit: 33
Perhaps it would be helpfull to know.
HHbomb
Postby neonZorglub » Thu Apr 22, 2021 9:41 pm
neonZorglub Thu Apr 22, 2021 9:41 pm
Hi HHbomb,
Those special statistics are displayed when you turn on "Enable Extra Render stat info" in Octane Preferences / Trouble Shooting.
Those are more intended for debugging, but could give some hint in case of issues.
rd: valid render count / converted image count
new: new image count, from render engine
cop: images copied from engine to render buffer
disc: images discarded
conv: images converted from render buffer to blit buffer (rgba..)
blit: images copied from the blit buffer to the visible viewport
When changing parameters, materials, etc while the render is in progress, the current rendered image is sometimes discarded, as a new render is restarted.
Some changes affect only the render buffer, like Exposure of Imager, so you will see those numbers increase, but the render steps from geometry will not change (smp/px)
Some parameter change should have no effect (like the motion blur duration when motion blur is disabled), and nothing should change..
So, it can give an indication on how a parameter change affect the current rendering.
neonZorglub
Postby glimpse » Fri Apr 23, 2021 12:38 pm
glimpse Fri Apr 23, 2021 12:38 pm
neonZorglub wrote:Those special statistics are displayed when you turn on "Enable Extra Render stat info" in Octane Preferences / Trouble Shooting..
thanks for all the info!
glimpse
Postby HHbomb » Fri Apr 23, 2021 4:20 pm
HHbomb Fri Apr 23, 2021 4:20 pm
Thanks NZ. I don't understand all but it can give some clues.
HHbomb
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 17 guests
Fri Apr 26, 2024 7:56 am [ UTC ]
