Hi All,
I am hoping that someone here can assist in figuring out the most efficient workflow methodology for getting a revit model to Octane via Max,
The specific problem I am struggling with is how to deal with separating materials when importing to Max from Revit.
I have attached a screenshot of the output when I run the Octane obj creator. Whilst there are around 400 materials , figure in brackets, which have come across from revit to max, only 2 of those are being exported to the obj file. The only way I have found around this at the moment is to manually assign max materials to each of the object which will form part of the final render. Once Max materials have been assigned, the export is as expected. It is, a total PITA to have to assign materials three times. Once in Revit - then Max - Then Octane for the final tweaks.
Does anyone know of any easy (automated?) way of assigning max materials whilst maintaining the material name or of merging materials from revit into max material database?
