Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby mitchino » Fri Feb 23, 2024 11:32 am
mitchino Fri Feb 23, 2024 11:32 am
That's a great demo Padi - I am now convinced! Just need to decide whether to get an M1 or M2 now or wait until the M3 Ultra drops...
mitchino
Postby mitchino » Fri Mar 08, 2024 8:43 am
mitchino Fri Mar 08, 2024 8:43 am
Question about mac/pc network rendering: Does Octane use the unified memory from the mac i.e. up to 128GB or is it restricted to the card(s) in the PC i.e. 24GB on a 3090/4090?
mitchino
Postby bepeg4d » Mon Mar 11, 2024 7:53 am
bepeg4d Mon Mar 11, 2024 7:53 am
since the mac is the primary workstation, it is using the max VRAM with unified memory in Apple Silicon.
If the scene goes over ~20GB of used VRAM, the Render-Node can fail, but you can enable the Out-of-core in the Render-Node, to have more room.
Obviously, always better to have the whole scene completely loaded in VRAM, without Out-of-core active.
ciao,
Beppe
Postby jc0 » Thu Mar 14, 2024 7:13 pm
jc0 Thu Mar 14, 2024 7:13 pm
Hey all, is there anywhere I can see Octane Bench results for MacBook Pros running the base M3, vs the M3 Pro and Max?
I just bought an M3 MacBook Air for personal use (not rendering) but am wondering if I should return it and go for a MacBook Pro with the M3 Max chip. I'd then be able to use it for 3D work when I'm 'on the go'. I use a PC for my 3D work, with 2 x 3090s. I loaded a scene which takes 28 seconds for my PC to render a frame of... it took my M3 MacBook Air 44 minutes! So unless the M3 Max is vastly superior then I'd probably stick with the MacBook Air and rule out doing much/any 3D work on it. Thanks!
jc0
Postby bepeg4d » Fri Mar 15, 2024 8:25 am
bepeg4d Fri Mar 15, 2024 8:25 am
please follow this link and share your result with M3 base, and I'll update the chart.
viewtopic.php?f=7&t=75411&start=1320#p421617
M3 Max result is ~15".
Anyway, please consider that Apple Silicon is always slower in rendering, compared with CUDA, but it is faster in all the other tasks (eg AI Denoiser), and with 2024.1-Alpha versions you can use both 2x RTX 3090 via Net render.
viewtopic.php?f=7&t=75411&start=1580#p430565
ciao,
Beppe
Postby jc0 » Fri Mar 15, 2024 4:57 pm
jc0 Fri Mar 15, 2024 4:57 pm
Thanks Beppe, here's my result with an M3 MacBook Air, 16GB - 51 seconds
jc0
Postby bepeg4d » Mon Mar 18, 2024 8:03 am
bepeg4d Mon Mar 18, 2024 8:03 am
jc0 wrote:Thanks Beppe, here's my result with an M3 MacBook Air, 16GB - 51 seconds
Roughly more than 3x faster than M1 base!
Here is the updated chart:
ciao,
Beppe
Postby mitchino » Fri Mar 29, 2024 9:26 am
mitchino Fri Mar 29, 2024 9:26 am
I've just got a mac mini M2 Pro and I'm having trouble setting up Octane Network rendering. On my PC I've installed the OctaneRender Studio+ 2023.1.2 Daemon, set to the default port of 48000.
On the mac mini, I have c4d running the Octane 2023.1.2-[R6] plug-in.
When I open the live viewer and choose Network Rendering>Settings, nothing happens. If I go to render settings>Octane Renderer>Network Preferences, nothing happens.
The two machines are plugged in using ethernet to a Netgear gigabit switch.
Where am I going wrong?
mitchino
Postby mitchino » Fri Mar 29, 2024 10:04 am
mitchino Fri Mar 29, 2024 10:04 am
OK, found out I needed to have the 2024_Alpha_3 installed on the Mac.
Now I can open the network preferences but not sure what's wrong:
mitchino
Postby JoGo23 » Fri Mar 29, 2024 1:50 pm
JoGo23 Fri Mar 29, 2024 1:50 pm
You need to have the 2024_Alpha_3 on both sides.
JoGo23
PreviousNext
Return to Autodesk 3Ds Max
Tue Jun 04, 2024 11:19 am [ UTC ]
