Forest pack and render Layer ID pass.
Forums: Forest pack and render Layer ID pass.
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby HHbomb » Fri Jul 22, 2022 7:41 am
HHbomb Fri Jul 22, 2022 7:41 am
I can't understand how to give FP objects a render layer ID pass.
In old times FP was always 1... not fun but ok.
Now my Fp was in layer 2... and I didn't know why ? because all elements was 1...
I select all scene objects and set to layer 1, ok now it is 1, but I don't know whaty I did...
Any clue ?
Thanks.
HHbomb
Re: Forest pack and render Layer ID pass.
Postby paride4331 » Fri Jul 22, 2022 10:35 am
paride4331 Fri Jul 22, 2022 10:35 am
Hi HHbomb,
I'm not sure I got what you are saying, but you should assign the Object layerd ID you want, active the render layer then refresh the OctaneRender viewport.
paride4331
Postby HHbomb » Mon Jul 25, 2022 2:10 pm
HHbomb Mon Jul 25, 2022 2:10 pm
Hi Paride.
Here is a simple scene :
- a plane with Render Layer ID 1
- a teapot with ID 2
- a Forest Pack object with ID 2
I would like to have Fp object in green in the Render Layer id pass.... but no.
RENDER layer ID 001.zip
(54.28 KiB) Downloaded 86 times
HHbomb
Postby paride4331 » Tue Jul 26, 2022 3:17 pm
paride4331 Tue Jul 26, 2022 3:17 pm
Hi HHbomb,
Is there any chance you you are using object layer color instead of Render layer ID?
paride4331
Postby HHbomb » Tue Jul 26, 2022 4:21 pm
HHbomb Tue Jul 26, 2022 4:21 pm
Hi, I use lastest octane render version now (2021.1.5_-_12.22) and if I want to change Render layer ID of forest pack objects , I need to change RL ID of Forest Pack object itself ( not its objects in Geometry tab )
HHbomb
Postby neonZorglub » Tue Jul 26, 2022 11:01 pm
neonZorglub Tue Jul 26, 2022 11:01 pm
HHbomb wrote:Hi, I use lastest octane render version now (2021.1.5_-_12.22) and if I want to change Render layer ID of forest pack objects , I need to change RL ID of Forest Pack object itself ( not its objects in Geometry tab )
Hi HHbomb,
That's strange, I also can't reproduce the issue.
Your scene works fine for me too; I get the FP teapots in green, layer ID 2..
Could you try this scene :
RLayerID_2_passRLid.zip
(60.76 KiB) Downloaded 73 times
I just added the Render layer ID pass, and set the teapot layer ID to 3
If you just open the Octane viewport and set the current pass to Render layer ID, you should get this:
Note that in Render settings / Support / Forest pack, the 'Use layer from FP object' is enabled, so it will use the layer ID from Forest001 (layer ID 2).
You could try to disable it, to check that it takes the ID from the referenced object as expected (Teapot001, layer ID 3)
The issue could come from some of the Octane Preference settings, but I couldn't find one that would do this..
Could you try Preferences / menu Preset : Reset Default settings ?
I tested with Forest pack 6.3.1 and 7.4.1.. what version do you use ?
neonZorglub
Postby HHbomb » Thu Jul 28, 2022 10:02 am
HHbomb Thu Jul 28, 2022 10:02 am
Hi NZ,
I use OR 2021.1.5.12.22 now.
I reset default settings of Octane preferences. Now it works fine.... What was the problem is now a mystery...
Thanks.
HHbomb
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 11 guests
Mon Jun 17, 2024 4:58 pm [ UTC ]
