Opacity bug (alpha shadow issue)
Forums: Opacity bug (alpha shadow issue)
Please post only in English in this subforum. For alternate language discussion please go here viewforum.php?f=18
Postby javierluisbravo » Mon Jun 21, 2021 8:35 pm
javierluisbravo Mon Jun 21, 2021 8:35 pm
here again with this bug that seems silly but it's not...
it seems it's something related to the alpha shadow calculation as it's not well calculated when there are intersectios.
I will share the scene in next post.
It should not happen this...
thanks!
Javier
javierluisbravo
Re: Opacity bug (alpha shadow issue)
Postby javierluisbravo » Mon Jun 21, 2021 8:38 pm
javierluisbravo Mon Jun 21, 2021 8:38 pm
here previous max scene...
hope you can find a solution... as for a bird or grass or whaterver where you use opacity maps... this is needed to be rendered properly where the geo intersects (but the alpha channel not)...
thanks
test_opacity_fail02.zip
(353.99 KiB) Downloaded 92 times
javierluisbravo
Postby paride4331 » Tue Jun 22, 2021 1:53 pm
paride4331 Tue Jun 22, 2021 1:53 pm
Hi javierluisbravo,
in this case try to set the Ray epsilon (Kernel Panel) to 0,000001
paride4331
Postby javierluisbravo » Tue Jun 22, 2021 7:35 pm
javierluisbravo Tue Jun 22, 2021 7:35 pm
Thanks..
Octane does not allow me to put so many ceros there.. but i put it in 1.. and then i put in 0.. and it got fixed....
there's a bug in the spinner there... just to let you know.
thanks for the fix!
javierluisbravo
Postby paride4331 » Wed Jun 23, 2021 7:32 am
paride4331 Wed Jun 23, 2021 7:32 am
Hi javierluisbravo,
paride4331
Return to Autodesk 3Ds Max
Users browsing this forum: No registered users and 13 guests
Thu May 09, 2024 11:07 pm [ UTC ]
