crash report, can't render some scenes.
Forums: crash report, can't render some scenes.
Postby BluJodeci » Fri Sep 15, 2023 12:13 pm
BluJodeci Fri Sep 15, 2023 12:13 pm
Hello everyone, I'm having troubles with octane and I hope that some of you can help me.
I've been using Octane with blender for more than a year now (free Octane X version for OSX).
but for some reason sometimes when I try to see the viewport render or when I try to render I have an ERROR. when I check the log this is what I get.
This often happens when I try to render Daz Studio Assets.
I am on Macbook pro M1
Started logging on 15.09.23 13:44:27
Octane X Prime 2022.1.1 (12000102)
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x154717810) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x154708db0)
Node type 33 is either unknown, a linker or incompatible to static pin 'groundColor' (P_GROUND_COLOR, type PT_FLOAT) of node 'Environment' (NT_ENV_DAYLIGHT, 0x15471e740)
tried to send change event for null item or empty pin array
Tried to access null node pin
Tried to access pin via an invalid ID P_UNKNOWN (0)
Can't read bool from static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 0x10fa0c940)
Tried to access pin via an invalid ID P_OLD_VOLUME_BEHAVIOR (448)
Tried to access pin via an invalid ID P_USE_OLD_COLOR_PIPELINE (708)
Compute error 2097152:6199234486295259741:3423:
Compute error 2097152:6199234486295259741:3423 on device 0:
device 0: direct light kernel failed
Compute error 1048576:3323667432514165251:3660:
Compute error 1048576:3323667432514165251:3660 on device 0:
Compute error 2097152:3323667432514165251:950:
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x154604f50) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x154723980)
Node type 33 is either unknown, a linker or incompatible to static pin 'groundColor' (P_GROUND_COLOR, type PT_FLOAT) of node 'Environment' (NT_ENV_DAYLIGHT, 0x15460dba0)
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x15461eb00) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x156308a20)
Node type 33 is either unknown, a linker or incompatible to static pin 'groundColor' (P_GROUND_COLOR, type PT_FLOAT) of node 'Environment' (NT_ENV_DAYLIGHT, 0x154715a90)
Can't connect node 'OCTANE_BLENDER_RENDER_PASS_NODE' (NT_TEX_SPOTLIGHT, 0x15461f180) to static pin 'renderPasses' (P_RENDER_PASSES, type PT_RENDER_PASSES) of node 'Render target' (NT_RENDERTARGET, 0x108df8080)
Node type 33 is either unknown, a linker or incompatible to static pin 'groundColor' (P_GROUND_COLOR, type PT_FLOAT) of node 'Environment' (NT_ENV_DAYLIGHT, 0x156285d30)
BluJodeci
Return to Demo Version Questions & Discussion
Users browsing this forum: No registered users and 20 guests
Tue May 21, 2024 9:51 am [ UTC ]
