Hi all,
As the title describes I am facing a problem trying to render with dual GPUs. After a couple of frames the the PC reboots it self.
I have set the priority to medium or even to low but with now change... I also tick the C4D settings "use all gpus"
Also when I render in the live view using both gpus the frame takes 11 seconds to compile.
But when render the final scene crashes all the times..
I checked the stability of the computer using Prime 95, Furmark, etc and temps etc all are fine..
The setup consists of:
mob: Asus Rog Extreme Zenith II Alpha
cpu: AMD 3970X
ram: 256GB
gpu: 2 x 3090 RTX
psu: 1500w
Is there any suggestion cause can not make use of the render at all?
