Blender Octane doesn't update mesh when rendering animation
Forums: Blender Octane doesn't update mesh when rendering animation
Postby condopony » Sat Mar 28, 2020 5:25 pm
condopony Sat Mar 28, 2020 5:25 pm
I've got a mesh animated with an armature. Whenever I render one frame everything is fine but when I render the whole animation the armature seems stuck on the pose it started rendering in. Interestingly I've also parented an object to a triangle on the mesh and this object is rendered where the mesh is supposed to be.
Are there any settings in Octane for Blender that could explain this problem? I've tried all sorts of things but it doesn't seem to matter.
The link below shows frame 25 and 32. The mesh is supposed to have moved but only the light ring on the visor seems to have moved to the right location where the mesh is supposed to be.
https://imgur.com/a/uwxvCWu
condopony
Re: Blender Octane doesn't update mesh when rendering animation
Postby bepeg4d » Mon Mar 30, 2020 6:58 am
bepeg4d Mon Mar 30, 2020 6:58 am
I think you need to set the Geometry Type to Movable proxy, please, have a look at here:
https://docs.otoy.com/BlenderH/BlenderP ... yTypes.htm
Postby condopony » Mon Mar 30, 2020 8:28 am
condopony Mon Mar 30, 2020 8:28 am
Thanks Beppe, that solves it.
condopony
Postby GinoFernandez » Wed Aug 05, 2020 6:54 pm
GinoFernandez Wed Aug 05, 2020 6:54 pm
Is there a reason these options would be greyed out? I can't select moveable or global etc. Well I can but it's just greyed out so I assume it doesn't do anything. My armature animation isn't rendering at all, it's just stuck on the first frame like OP.
GinoFernandez
Postby dokutaiyo » Sat Nov 28, 2020 6:37 am
dokutaiyo Sat Nov 28, 2020 6:37 am
im having the same issue but i dont have the mesh type option under Octane Properties
https://imgur.com/a/Yo29RA1
im using Blender 2.3
dokutaiyo
Postby sudzy » Sat Dec 12, 2020 1:51 pm
sudzy Sat Dec 12, 2020 1:51 pm
In the object properties change the object type to "reshapable proxy"
sudzy
Postby nyanpost » Tue Mar 23, 2021 10:48 pm
nyanpost Tue Mar 23, 2021 10:48 pm
dokutaiyo wrote:im having the same issue but i dont have the mesh type option under Octane Properties
This option is now in Object Properties, it has an icon of a yellow square in a menu.
Changing the object type to Reshapable Proxi also solved the problem for me — I had a boolean reveal animation that did not show up in renders.
I am using Blender 2.91.2
nyanpost
Postby Approximated » Fri Apr 09, 2021 7:33 am
Approximated Fri Apr 09, 2021 7:33 am
Im having the same issue but movable and reshape able proxy are not fixing it. My armature is a animated fbx file imported into blender. Please help
EDIT: Turns out that you have to have adaptive sampling turned off or else the models wont update even if it is on reshape or movable proxy
Approximated
Return to Demo Version Questions & Discussion
Who is online
Users browsing this forum: No registered users and 33 guests
Fri Apr 26, 2024 5:40 pm [ UTC ]
