Enabling Panorama in Cinema4D
Forums: Enabling Panorama in Cinema4D
Postby DanielArnett » Tue Jun 17, 2014 7:50 pm
DanielArnett Tue Jun 17, 2014 7:50 pm
Octane Standalone generates beautiful Panoramas in a simple, user-friendly way.
My issue arises when I try to render a Cinema4D scene as an Octane Panorama.
    Attempting a panorama.
Switching between Thin Lens and Panorama does not appear to make any changes to how the camera operates in the plugin. Where does my problem lie? Is it a setting in OctaneRender that I am missing, a problem with my Cinema4D camera or render settings, or is a software error?
Here are the basic camera settings that I am using.
I will buy Octane as soon as this problem is resolved.
DanielArnett
Re: Panorama Problems in Cinema4D
Postby aoktar » Tue Jun 17, 2014 8:28 pm
aoktar Tue Jun 17, 2014 8:28 pm
can you plase change the title? it's not a problem. we use camera tag. this and others are documented in manual
Re: Enabling Panorama in Cinema4D
Postby DanielArnett » Tue Jun 17, 2014 8:54 pm
DanielArnett Tue Jun 17, 2014 8:54 pm
Edit: Okay that's good to know. Is there any way to render a 360 panorama in tag? Or will I have to export to the standalone?
Thank you for your help, and for your work making this fantastic tool. I have read the Cinema4D Octane plugin manual section on the Octane Camera,
http://render.otoy.com/manuals/Cinema4D/?page_id=1944
and it explains how easily the user can switch between the Thin Lens and Panoramic cameras. When I switch between the two in the Octane camera tag and adjust the fov settings in the Panorama section I see no immediate impact on the rendered image.
I am using R.15 with the current Demo version of Octane Render.
Last edited by DanielArnett on Tue Jun 17, 2014 10:45 pm, edited 2 times in total.
DanielArnett
Postby aoktar » Tue Jun 17, 2014 9:04 pm
aoktar Tue Jun 17, 2014 9:04 pm
fov is only parameter which is not functional in tag. it will be deprecated. you can set fov from camera
best regards,
ahmet oktar
Postby DanielArnett » Sun Jul 13, 2014 10:23 pm
DanielArnett Sun Jul 13, 2014 10:23 pm
Thank you again Ahmet,
So are you saying that Tag just will not generate Panoramas? I have looked into all of the Octane guides that I can find, and I still cannot find a way to render panoramas in tag. Please any help would be appreciated and like I said- this would be the main reason I purchase Octane & the C4D plugin.
DanielArnett
Postby aoktar » Sun Jul 13, 2014 10:34 pm
aoktar Sun Jul 13, 2014 10:34 pm
Check please the octane cameratag. It's here
Postby DanielArnett » Mon Jul 14, 2014 2:36 pm
DanielArnett Mon Jul 14, 2014 2:36 pm
So cool! I'll check it out tonight, see what I can do and post any results/questions that I have later on.
DanielArnett
Postby mfriel » Wed Apr 01, 2015 7:24 am
mfriel Wed Apr 01, 2015 7:24 am
DanielArnett wrote:So cool! I'll check it out tonight, see what I can do and post any results/questions that I have later on.
Hi Daniel,
did you get it to work?
I'm still struggling to render a spherical Panorama with Octane in Cinema.
I activated the checkbox in the Octane Camera Tag of the Demo, but with no visible result in the Render Viewer.
What am i doing wrong?
mfriel
Postby nickarts » Mon Jul 06, 2015 10:49 am
nickarts Mon Jul 06, 2015 10:49 am
I want to use Octane with C4D strictly for 360 panoramas and I also run into the problem mentioned above, but unfortunately all posts that mention this don't come up with a solution.
I'm using the Octane Camera Tag but when I set it to Panoramic, I don't get a panoramic render, no matter which settings I change. Stereo works fine, but I'm after Panoramic Stereo.
I want to get the result in the screenshot above, which is made from a Windows version, so maybe it's a Mac bug? Or is it a bug in the demo and does it work in the full version?
I'm using
Octane Render Demo 2.17
Octane Live Viewer Demo 2.32.2 RC4
C4D R16.050
MAC OSX 10.10.3
Macbook Pro Retina (CUDA capable)
Regards,
NickArts
nickarts
Postby nickarts » Mon Jul 06, 2015 3:06 pm
nickarts Mon Jul 06, 2015 3:06 pm
[Double Post]
nickarts
Next
Return to Demo Version Questions & Discussion
Who is online
Users browsing this forum: No registered users and 6 guests
Sun Jun 16, 2024 2:54 am [ UTC ]
