Cinema 4d plugin Spots light, ambient oclusion problem.
Forums: Cinema 4d plugin Spots light, ambient oclusion problem.
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby Adiaz » Sun Apr 11, 2021 11:45 pm
Adiaz Sun Apr 11, 2021 11:45 pm
Hello everybody.
First of all I'm sorry, I can't put this post where it belongs but it just lets me open a new post in this group.
My problem is that when I use octane inside cinema 4d and put a spotlight, the beam from that spotlight leaves a black spot in the ambient occlusion, I understand that this is because by default this type of light creates a fog, but I am not capable to deactivate the fog or get me to remove that black beam in the ambient occlusion.
Someone could tell me how it can be solved
Thank you very much, greetings.
Adiaz
Re: Cinema 4d pluging Spots light, ambient oclusion problem.
Postby bepeg4d » Mon Apr 12, 2021 6:22 am
bepeg4d Mon Apr 12, 2021 6:22 am
you need to remove the Scattering medium node in the attributes of the Spotlight, or adjust its values to have a more correct volumetric effect:
![](download/file.php?id=83698&mode=view)
ciao Beppe
Re: Cinema 4d plugin Spots light, ambient oclusion problem.
Postby Adiaz » Mon Apr 12, 2021 9:35 am
Adiaz Mon Apr 12, 2021 9:35 am
Thanks for answering so quickly.
I think the error is there, but in light settings I do not get the light medium options. Also if I get into the nodes I get the nodes without links, and even if I delete them I still have the same problem. Here I leave you screenshots of the ambient occlusion (Sorry, I don't know how to upload them directly to the forum)
https://ibb.co/RQrhMwW
https://ibb.co/N1f4kpX
Thank you so much
Adiaz
Postby bepeg4d » Tue Apr 13, 2021 7:43 am
bepeg4d Tue Apr 13, 2021 7:43 am
Ok, now the issue is more clear.
The solution is to replace the Volume SpotLight with a normal Area Light with reduced dimensions, and add the new Spotlight Distribution node in the Distribution pin:
Here is an example scene:
SpotDistribution.zip
(73.17 KiB) Downloaded 173 times
ciao Beppe
Postby Adiaz » Tue Apr 13, 2021 9:07 am
Adiaz Tue Apr 13, 2021 9:07 am
bepeg4d wrote:Ok, now the issue is more clear.
ciao Beppe
Many thanks. With this it is solved!
Thanks for the speed when answering.
Adiaz
Return to Resources and Sharing
Users browsing this forum: No registered users and 77 guests
Fri Apr 26, 2024 11:51 pm [ UTC ]
