Octane composite material node + Octane colors Layer 3dsMax
Forums: Octane composite material node + Octane colors Layer 3dsMax
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Postby paride4331 » Tue May 12, 2020 3:24 pm
paride4331 Tue May 12, 2020 3:24 pm
Hi guys,
here the workflow from Vray BlendMtl + 3dsMax composite to Octane render.
paride4331
Re: Octane composite material node + Octane colors Layer 3dsMax
Postby samsue » Tue May 12, 2020 8:23 pm
samsue Tue May 12, 2020 8:23 pm
I didn't quite understand
samsue
Postby nildoe » Wed May 13, 2020 2:46 am
nildoe Wed May 13, 2020 2:46 am
I also would like better clarification...
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
nildoe
Postby paride4331 » Thu May 14, 2020 9:51 am
paride4331 Thu May 14, 2020 9:51 am
Hi guys,
in reference to this post:
https://render.otoy.com/forum/viewtopic.php?f=27&t=56222&p=289365&hilit=composite#p289365
3D libraries can be used with this materials and textures workflow.
We will soon have a composite layer node, in the meantime we can use this OSL layer texture.
paride4331
Postby jimho » Wed May 20, 2020 12:00 pm
jimho Wed May 20, 2020 12:00 pm
Thanks Paride for the information.
I would like to know what is the mask tx #1 for , it seems no difference between there is or not a mask linked here
Supermicro 4028GR TR2|Intel xeon E5 2697 V3| windows 10| revit 2019 |Titan V+ Quadro GV100+RTX 2080 Ti
jimho
Postby paride4331 » Thu May 21, 2020 7:41 am
paride4331 Thu May 21, 2020 7:41 am
Hi jimho,
it works adding a new material slot.
paride4331
Postby jimho » Fri May 22, 2020 1:12 am
jimho Fri May 22, 2020 1:12 am
if there is no difference when putting mask there, should it be taken out from the UI?
jimho
Postby paride4331 » Fri May 22, 2020 7:50 am
paride4331 Fri May 22, 2020 7:50 am
jimho wrote:if there is no difference when putting mask there, should it be taken out from the UI?
Hi jimbo,
composite material UI is like in SA, I can ask that to 3dsMax devs but I'm not sure if it possible.
paride4331
Return to Resources and Sharing
Users browsing this forum: No registered users and 66 guests
Sat Apr 27, 2024 9:33 am [ UTC ]
