sudisk wrote:Hello,
I can confirm that behavior with the live button enabled.
I did however do something wrong, but I couldn't recover from it:
- I started working on the scene, and added a G8 character (if it matters)
- When I started working on expressions, I was on the DAZ posing tab, not parameters tab, and the expression wasn't registered.
- I used the "Reload on demand" command to realign the expression and it worked
- I switched back to the parameters tab and then none of my pose change was registered automatically. I needed to do a manual reload to have it taken into account.
I looks like the live feature was disconnected from the scene and couldn't recover from it.
I hope this helps.
Hello Sudisk,
Thank you for having a look.
Yes, I have the same experience that sometimes the live feature could recover.
When you say the expression, is it a facial expression or just the poses with G8?
Thank you!
