Ainionu wrote:So denoiser in PR14 on M1 does not work right? Or is there some kind of trick I don't know about? It does not crash it simply cannot finish rendering... Without denoiser it renders about two minutes one frame, with denoiser turned on my patience ended after twenty minutes when renderer still hadn't finished rendering. Any suggestions?
bepeg4d wrote:M1 chip is completely different from previous CPUs, and does not have the necessary AVX2 instructions for performing AI Denoiser, and Denoised passes.
So AI Denoiser, and denoised passes must to be disabled, or the render never finishes.
Alternatively, you can try with Hot pixel removal slider in Camera Imager node, but avoid to go under 0.65, and consider that it is distructive, so you can have artifacts.
Another option is to try with internal C4D Denoiser in Picture Viewer, but it is not like AI Denoiser:
ciao,
Beppe
Users browsing this forum: No registered users and 19 guests
