Missing the Shader Out Socket
Forums: Missing the Shader Out Socket
Sub forum for bug reports
Postby AlexeyAdamitsky » Tue Nov 14, 2023 7:36 pm
AlexeyAdamitsky Tue Nov 14, 2023 7:36 pm
Using the latest RC4 build. The Material Builder is missing the shader out socket. It makes it impossible to connect to the collect node to allow different renderers to load appropriate materials for each render.
AlexeyAdamitsky
Re: Missing the Shader Out Socket
Postby BK » Tue Nov 14, 2023 10:05 pm
BK Tue Nov 14, 2023 10:05 pm
AlexeyAdamitsky wrote:Using the latest RC4 build. The Material Builder is missing the shader out socket. It makes it impossible to connect to the collect node to allow different renderers to load appropriate materials for each render.
Hi AlexeyAdamitsky,
Thank you again for this.
Correct, the Material builder and other texture node we have in OctaneSolaris is from the Houdini main plugin.
The workaround to use the collect node is to use normal Octane Material>out material node then pin into the collect node.
We plan to implement OctaneSolaris Material builder for Houdini 20.
cheers
Kind Regards
bk3d
BK
Return to Bug Reports
Tue Jun 04, 2024 5:00 am [ UTC ]
