cyrillweiss wrote:BK wrote:Just ran a quick animation Frame render and the Render to disk worked fine.
Would you please make sure that the **Render Node** is still selected when you ran the Viewport render?
Sorry, if I wasn't clear.
The Viewport render works with the **Render Node**, but the **Render Node** doesn't do any work, when I use "Render to Disk" or "Render to MPlay".
I've attached the **Render Node** Log. While it rendered with the viewport, there is no entry about that event.
Cheers
hi Cyrill,
Thanks for sharing the log file. Looks like the render node did not receive any data to process.
Would you please check if the master node sends data during the Viewport render?
The log should have time..ip etc..
We need to leave the **Enabled network rendering** and the **network daemons** options checked/enabled.
This way Render to disk command can pick up the render node automatically!
If this does not work then we recommend checking the Windows firewall or antivirus blocking the data transfers.
Or please feel free to reach out at *[email protected]* for further investigation.
cheers
