Octane off sync with LW image sequence.
Forums: Octane off sync with LW image sequence.
Sub forum for bug reports
Postby xevious2501 » Fri Jul 30, 2021 1:48 pm
xevious2501 Fri Jul 30, 2021 1:48 pm
Octane off sync with LW image sequence. multiple LW versions.
This has occurred before,
Octane will be a frame offset from lw's image sequence.
This happens both in 24fps and 23.976
crazy enough, when the actual anim is sync with the footage LW will show one frame and octane will be another but in sync with the object.
understandably this is a huge issue when trying to get work done.
Any remedy? :?
xevious2501
Re: Octane off sync with LW image sequence.
Postby promity » Fri Jul 30, 2021 3:26 pm
promity Fri Jul 30, 2021 3:26 pm
can you post a small version of your scene with this problem?
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
Postby juanjgon » Sat Jul 31, 2021 9:49 am
juanjgon Sat Jul 31, 2021 9:49 am
Yes, a repro scene could help. I think that I've not seen this problem before. Are you working with floating frame numbers or something like that?
juanjgon
Return to Bug Reports
Sun Apr 28, 2024 1:32 am [ UTC ]
