Octane 2021.1 for Unreal Engine - 0.49: Brushes & Switch
Forums: Octane 2021.1 for Unreal Engine - 0.49: Brushes & Switch
Moderator: ChrisHekman
Postby ChrisHekman » Fri Jan 28, 2022 6:03 pm
ChrisHekman Fri Jan 28, 2022 6:03 pm
Octane for Unreal Engine 0.49
Changes:
  • Added support for Brushes
  • Added Alembic and FBX options for static scene export to ORBX
  • Added Octane Switch Node Expression for unreal materials. Allows the user to alter parts of their Unreal Materials for rendering in Octane without having to change the appearance in Unreal.
  • Material conversion now defaults to GGX Energy Preserved bxdf
Fixes:
  • Octane material converter no longer takes the "raytracer" path, as this is only intended for "bounced light"/secondaries
  • Added new options to Material conversion BRDF in the plugin settings
  • Fixed issues with transforms in shaders from and too camera space
  • ScreenPosition node works correctly again
UE 4.26
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_26.exe
UE 4.27
Studio Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... UE4_27.exe
UE 5.0EA
Studio Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
Enterprise Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
Free Version Installer: https://www.otoyserver.com/unrealengine ... E5_0EA.exe
ChrisHekman
Re: Octane 2021.1 for Unreal Engine - 0.49: Brushes & Switch
Postby mrfactory » Sat Jan 29, 2022 11:00 am
mrfactory Sat Jan 29, 2022 11:00 am
Hello, there is a color difference in 4.27 between Octane Viewport and UE4 viewport.
I've been trying to match colors using Ocio either in Octane or UE4 but can't find the way.
Questions:
Is it possible to match colors between UE4 and Octane plugin as it was before?
How can i use Ocio within Octane Render Plugin for UE4?
Thanks for creating great software.
Best Regards
mrfactory
Postby mrfactory » Sun Jan 30, 2022 9:52 pm
mrfactory Sun Jan 30, 2022 9:52 pm
Hello, is there any plan to support landscape brush and instancing anytime soon.
If it is supported, haven't been successful to find the way.
Thanks for creating great software!!
Best Regards
mrfactory
Postby ChrisHekman » Mon Jan 31, 2022 1:27 pm
ChrisHekman Mon Jan 31, 2022 1:27 pm
mrfactory wrote:Hello, is there any plan to support landscape brush and instancing anytime soon.
Best Regards
That is odd. Instancing/Foliage is supported and is showing up in my test scenes.
Could you send me your scene so I can figure out what is going wrong?
mrfactory wrote:Hello, there is a color difference in 4.27 between Octane Viewport and UE4 viewport.
Questions:
Best Regards
The problem here are the sunsky systems, not the color system.
Unreals synsky system gives a slight blue tint to the scene, while octane gives a slight pink/reddish tint to the scene
I am not familiar with ocio mystelf, but I believe you need to set the ocio from inside the Octane GUI preference menu.
The octane plugin strives to duplicate color inputs correctly, however the unreal tonemapper and the Octane imager create differences in results.
Effectively, we try to aim to keep the results between the unreal "Post tonemap HDR color" buffer visualisation in unreal, and the default octane imager the same.
If you want to reproduce the default unreal tonemapper you can use the following settings: (turn off eye adaption though)
ChrisHekman
Postby mrfactory » Mon Feb 07, 2022 8:43 am
mrfactory Mon Feb 07, 2022 8:43 am
Thanks so much for your fast answer. Sry for the delay in answering. Tested and foliage works perfectly.
Best Regards
Scene created using Octane Render plugin as a Ground Truth
Instanced foliage tested. Baking grass with UE4 is almost impossible, would take AGES. Can't wait for Brigade.
mrfactory
Return to Releases
Users browsing this forum: No registered users and 8 guests
Fri Apr 26, 2024 6:11 pm [ UTC ]
