Workflow c4d->octane->ue4
Forums: Workflow c4d->octane->ue4
Unreal® Engine Integrated Plugin
Moderator: ChrisHekman
Postby lucioing » Sat Nov 30, 2019 2:05 pm
lucioing Sat Nov 30, 2019 2:05 pm
Hi!
I’m octane for C4d since 2014 and I ‘m very happy.
Now, It’s time to get over.
So, some weeks ago I’ve start to move to UE4 thanks
The Datasmith that make everthing very easy from
Cinema ti Unreal engine.
My question is: how to use the octane plugin for UE?
Can I export my scene using octane materials? (Ar the moment
just c4d materals works) and can I bake the scene as I do
now? Or I have to use RTX. cards?
Thank you.
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
lucioing
Re: Workflow c4d->octane->ue4
Postby StyleMarshal » Mon Dec 02, 2019 2:11 pm
StyleMarshal Mon Dec 02, 2019 2:11 pm
Hi lucioing ,
The easiest way to do it is to export your c4d scene or parts of it as an ORBX or animated ORBX file.
In Unreal Octane just import it as "ORBX scene as proxy".
It works very well for me and you don't have to tweak your materials again.
best :-)
StyleMarshal
Postby lucioing » Mon Dec 02, 2019 6:02 pm
lucioing Mon Dec 02, 2019 6:02 pm
First of all, thank you for your reply... ;)
The second: what about Octane for Unreal? Is it free? can I have a trial or demo version? Can I install it, using my my license?
So, if I understood, I can work as always in c4d and octane materials; then export orbx file...
Ok!
Thank you!
L.
lucioing
Postby ChrisHekman » Tue Dec 03, 2019 10:23 am
ChrisHekman Tue Dec 03, 2019 10:23 am
lucioing wrote:First of all, thank you for your reply... ;)
Ok!
Thank you!
L.
During the Beta you can use Octane for Unreal with any existing Octane license. There is also a free tier you can subscribe to.
After the Betam, Octane for Unreal will follow the same licencing rules as the other plugins.
ChrisHekman
Postby lucioing » Wed Dec 04, 2019 7:56 pm
lucioing Wed Dec 04, 2019 7:56 pm
Thank you Chris!
L.
lucioing
Postby Respecognize » Thu Jan 19, 2023 5:47 pm
Respecognize Thu Jan 19, 2023 5:47 pm
How do I setup a ORBX as a proxy in unreal?
Respecognize
Postby Respecognize » Thu Jan 19, 2023 7:35 pm
Respecognize Thu Jan 19, 2023 7:35 pm
Cause this is what I see when I tried all the steps:
https://imgur.com/jNl21ct
Respecognize
Postby ChrisHekman » Mon Jan 23, 2023 4:41 pm
ChrisHekman Mon Jan 23, 2023 4:41 pm
Respecognize wrote:Cause this is what I see when I tried all the steps:
Are you using the latest version of the plugin?
Does this happen with all your ORBX files? or just this one?
Could you share your ORBX file?
You can open the ORBX asset via the content viewer. A nodegraph will then appear. If it is empty, something went wrong during importing.
Additionally, there should be an added geometry output node in there that has all the geo connected to it. If that is missing, nothing will show up either.
ChrisHekman
Postby 14bmwc780nike » Tue Apr 18, 2023 6:14 pm
14bmwc780nike Tue Apr 18, 2023 6:14 pm
I am experiencing the same. The ORBX file is fine and all the elements are there.https://i.imgur.com/gYOLEsT.png When I import as stated above, I only see the Octance symbol in the scene. https://i.imgur.com/OpnbxCm.png
Also, the live viewer doesn't appear to start/work.
Unreal and the Octane for Unreal plugin are current versions. Stand alone is 2022.1
H: C4D 2023 | Asus ROG X399-E sTR4 | Win 10 64bit Pro | AMD TR 1950X 3.4 GHz 16-Core | 64GB | 3070ti/3090
W: C4D 2023 | Asus WRX80E-SAGE| Win 11 64bit Pro| AMD TRPRO 5965WX 24-Core | 128GB | 3090Ti
Cheers,
Marcus | 3dconge.com | @RockingThePIxel
14bmwc780nike
Postby ChrisHekman » Mon Apr 24, 2023 11:24 am
ChrisHekman Mon Apr 24, 2023 11:24 am
14bmwc780nike wrote:I am experiencing the same. The ORBX file is fine and all the elements are there.https://i.imgur.com/gYOLEsT.png When I import as stated above, I only see the Octance symbol in the scene. https://i.imgur.com/OpnbxCm.png
When using an orbx as a proxy, you will only see the contents in octane, and not in unreal.
If you want to see objects in unreal, you will need to use the "Import ORBX scne (Convert)" option.
To start the live viewer, you need to select a rendertarget and press the render button.
ChrisHekman
Return to Unreal® Engine
Users browsing this forum: No registered users and 16 guests
Sun Apr 28, 2024 5:39 am [ UTC ]
